Oil level indicator problem in km indicator
08.05.2020 16:06 # 1
naksi
When you open the contact on the friends km indicator, the oil level indicator of the image sometimes shows the oil empty sometimes.
what is the problem when i check the oil from the oil from the engine full oil
08.05.2020 16:06 # 2
I have the same, when I first bought the car, I said "What's going on now?" And opened the hood and checked it. Then I got used to it, now it hangs on its head, sometimes it shows full, sometimes it is empty. Continue checking the level and oil quality from the dipstick once a week.
08.05.2020 16:06 # 3
34sea45
I run my gasoline so half tank 20 30 meters later, a quarter below this pointer problems genetics in pejoes probably
08.05.2020 16:06 # 4
naksi
Have you been so, did you not have a solution?
08.05.2020 16:06 # 5
34sea45
If it is not difficult to find a solution to this kind of needle problem, if the malfunction light is not lit, the fault should be taken from the instrument cluster.
08.05.2020 16:06 # 6
berk2309
change your oil sensor, but usually check with a lot of trust
08.05.2020 16:06 # 7
naksi
Do I know about the price, bro brother
08.05.2020 16:06 # 8
34sea45
Şahin Peugeot
Original Spare Parts
0216 631 10 80
0216 631 18 12
0533 301 88 06
I www.peugeotmarket.co
You can ask murat evening dresses more affordable than the prices in the market
08.05.2020 16:06 # 9
SZKR
I have the same problem, if there is no problem such as oil reduction, it is enough for me to look at the oil level from the rod at long intervals.
08.05.2020 16:06 # 10
berk2309
I do not know, brother, I have no knowledge
