oil level
08.05.2020 17:14 # 1
atlasbm
SA Arkaşlar
Is the indicator in the picture an oil level indicator in my research in the forum? If so, does that mean there is no oil? the level looks normal when looking from the dipstick
08.05.2020 17:14 # 2
Serkan
Yes, teacher vehicle oil level has fallen below the minimum level, check from the dipstick and if it is missing, intervene immediately. Sometimes there may be errors in the indicators, the healthiest is to control it from the dipstick.
Edit: Sometimes you don't pay attention to the screen because it is normal in the dipstick, sometimes it is parked on the slope.
Serco05 2012-12-26 00:02:29
08.05.2020 17:14 # 3
atlasbm
looking at the bar on the flat ground in the car parking lot and when the engine is cold. oil level one line below the top level. When I turn the first contact, this message flashes on the screen for 7-8 seconds and disappears.
08.05.2020 17:14 # 4
xMEGANx
sensor malfunction then & nbsp;
08.05.2020 17:14 # 5
Serkan
As I said, sometimes the screen can make such mistakes, some of them are self-correcting, some are permanent, you check regularly from the dipstick, when you get to the service, you can connect to the computer and find out why.
08.05.2020 17:14 # 6
atlasbm
I mean, you need to change the oil sensor. Mechanical control from the stick always makes more sense, but the human is afraid, after all. & nbsp;
08.05.2020 17:14 # 7
Serkan
Sir, don't worry about it, there is no problem after making sure you have the oil, I think changing the customer and it will be corrected spontaneously.
08.05.2020 17:14 # 8
atlasbm
Thank you very much for your help. greetings
08.05.2020 17:14 # 9
oozcan42
Serco05 friend said it right and let me add 11 get it on my indicator. 16:28
08.05.2020 17:14 # 10
atlasbm
:) Does he want to say something? I wonder :) so be prepared for everything :)) Although it is known that there is a chronic problem, it demoralizes the person :(
