Oil level |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Bipper | |
| 08.05.2020 21:30 | # 1 |
| 08.05.2020 21:30 | # 2 |
If you bought a vehicle with 266000 km, good luck, God does not cause any trouble, check the oil after 2000 km, check the road after you have parked. If you look at it, it will not cause any problems to the vehicle, but now you can replace it with a new one.
| 08.05.2020 21:30 | # 3 |
It cannot be understood in this way. Pull the stick out, clean it again, put it back in, then take it back and check it. If you take it out and look it, it is misleading. As far as I understand from the photo, you did so.
| 08.05.2020 21:30 | # 4 |
This is the way it is done as you said.
| 08.05.2020 21:30 | # 5 |
I bought the vehicle at a price of 40 thousand TL.
| 08.05.2020 21:30 | # 6 |
Then the oil may be a little too much. Like it's above the max level. Your vehicle has a high mileage but you have shown it to 6 7 masters. They all said no problem. Get on without fear. Although peugeot vehicles are electronically troubled, they are quite robust in terms of engines. Diesel engines with Peugeot production were used in ford fiestas for a long time. It is very successful in terms of fuel consumption and performance. If it is well maintained in gasoline engines, it will take a long time. There are many cars in the market that have reached 500 thousand km and their engine has never been opened. |
| 08.05.2020 21:30 | # 7 |
God bless you, sprinkle water inside me.
