Oil leaking from the oil filter cover
08.05.2020 21:28 # 1
MDKBKR
Hello friends. I have the 2007 model 1.4 8v petrol + lpg 206 vehicle. Oil is leaking from the oil filter cover of my vehicle. Cover 2 times, filter 3 times changed. Teflon tape wrapped 2 times. Nothing changed. If you have the same problem and find a solution, I am waiting for your help. Respects.
08.05.2020 21:28 # 2
ismailkaya
photo, let's see your picture
08.05.2020 21:28 # 3
x571
Nothing to spoil, actually. There should be a gasket when you remove the cover, there may be a problem. Didn't it fit the filter well? In a forum, I read that the citizen put the brake pad backwards. So if the man can put the lining upside down, he can do anything. Finally, the filter body is covered in teeth, and when you force it, it goes well and says it is cracked.
08.05.2020 21:28 # 4
I had the same problem. they either tighten the plastic cap too tightly or put it dry without lubricating it, which may cause the seal not to fit properly. sub-industry can be a problem in caps.
08.05.2020 21:28 # 5
MDKBKR
Thanks for your answers, friends. I will pay attention to gasket and tightening when I am going to change with new cover and filter in the near future.
08.05.2020 21:28 # 6
MDKBKR
The image is like this.
08.05.2020 21:28 # 7
ismailkaya
the covers are usually leaking. The original covers are around 120 TL. Try one fiat 1.3 1.6 miltijet oil cover.
