OIL LEAKAGE QUESTION?
08.05.2020 20:59 # 1
307XS307
Hello friends, we washed the bottom of the car, there is oil leakage from the crankcase cover, the masters said, but there is no reduction in engine oil. they couldn't look at it because of the density. I will go again on weekdays. what do you think could be?
I park the car in a different clean place every day, leaving a round oil-like oil stain under it every time
08.05.2020 20:59 # 2
307XS307
I even said that when the car was on the move, I went to the ATM the other day, I got out of the car and I said, I would look back and see it dripping visibly. the floor was as wet as a palm
08.05.2020 20:59 # 3
HasGur
[QUOTE = 307XS307] friends hello we washed under the car, there is oil leakage from the crankcase cover from there masters but there is no shortage in engine oil. they couldn't look at it because of the density. I will go again on weekdays. what do you think could be?
If the ground is not soil, and the ambient temperature is not low, 1 drop of oil can cover an area of 100 cm2 . 20 drops = 1 ml in medicines Smile One drop of oil has a volume of 50 mm3, since 1 m3 = 1.000.000.000 mm3 , it will take a long time to notice this in the dipstick if 10-15 drops of engine oil leak every day from the engine weight of about 870 kg.
