Oil Leak (with photo)
08.05.2020 20:38 # 1
ertugrulgurbuz
Friends leaned under the car, I came across with such a view, this oil is too big or a big problem I couldn't understand
08.05.2020 20:38 # 2
hermanito
check the oil level, have it checked immediately, without damaging the engine
08.05.2020 20:38 # 3
runiy06
Every flow creates a problem in my 206. First of all, there was an incontinence from the oil cap, and then it was from the oil cooler.
08.05.2020 20:38 # 4
RP393
Have the camshaft seal checked.
08.05.2020 20:38 # 5
ertugrulgurbuz
The engine oil level does not seem to be missing at all. Before that, there was a similar situation, the master looked, the oil sight changed, it was solved
Edit: Now it comes to my mind that there is a leakage in the power steering oil reduction reduction, I wonder if it may be adding the oil occasionally. ertugrulgurbuz 2017-11-06 01:18:25
08.05.2020 20:38 # 6
peugeotefe
The leak oil is caused by the filter log, it is not behind the heat because it is behind the exhaust
08.05.2020 20:38 # 7
uzunca961
Follow the hoses coming out of it, if my teacher is passing through, then it is hydraulic oil.
08.05.2020 20:38 # 8
ersinyildiz
The oil looks like a pressure sensor. It throws more while working, look under the vehicle, if the oil is spread backwards, it is likely to be from the customer.
It costs 50 lira with the workmanship.
08.05.2020 20:38 # 9
ertugrulgurbuz
[QUOTE = peugeotefe] Leak oil is caused by the filter slab because it is behind the exhaust does not withstand heat [/ QUOTE]
I looked at her as if the oil was overflowing from the filter pan. As our other friend said, oil flows backwards, there is no oil dripping on the ground or there is no decrease in the engine oil stick.
08.05.2020 20:38 # 10
ertugrulgurbuz
[QUOTE = ersinyildiz] The oil looks like a pressure sensor. It throws more while working, look under the vehicle, if the oil is spread backwards, it is likely to be from the customer.
It costs 50 lira with labor. [/ QUOTE]
When I first start the engine when the engine is cold in the morning, it leaves a drop of oil on the floor.
08.05.2020 20:38 # 11
samet206
There is no leakage if there is no missing when the liquid checks are done, but if there is dripping on the ground, the possibility of leakage is high. The reason I say this is sometimes they do not drain and clean the old oil when the oil is hot. I cleaned it with spray and it became clear that there was no leak.
08.05.2020 20:38 # 12
vpro
I have the same problem, did you solve the teacher?
08.05.2020 20:38 # 13
vpro
Where is my teacher exactly here
08.05.2020 20:38 # 14
vpro
Whatever has to do with the oil, the filter slab, the filter cap, luck scratches, oiled screws, I tighten them all. It has been cut for now. Car does not stand on the dented roads of Ankara
08.05.2020 20:38 # 15
nbol
I had a similar problem, when the engine was cold, the oil was missing at the first start, the problem was caused by the o-rings (gasket).
