Oil leak problem
08.05.2020 15:44 # 1
freedom206
Guys, I have a leak in my car. I took it to Bosh service, complete covers etc. in the engine compartment. They said it must be dismantled and cleaned and checked. They said that the labor cost may be 100-150 TL, although it is not exactly known. The car has only six oils, and after driving, there is a lot of oil under it. Why do you think it might be?
08.05.2020 15:44 # 2
freedom206
Nobody has any idea, guys? Disapprove
08.05.2020 15:44 # 3
It may be from the crankcase gasket. This problem was also in my old vehicle. Although it wasn't too faint, it was missing a little oil. It was said to be from the crankcase gasket. It had a price like 40TL piece + 20TL workmanship, if I don't remember wrong.
08.05.2020 15:44 # 4
freedom206
But my car also has greased sections on the sides of the engine. Is it missing from the top covers and gaskets?
08.05.2020 15:44 # 5
It would be more accurate if you took a photo of it.
08.05.2020 15:44 # 6
aslan206
The problem is most likely caused by the gasket on the top cylinder head, and it may be missing from the seals. Look at the first leak, the gasket will change if it is from the place where the gasket is. If it is not, it may be from felts. -200 TL for cylinder cover welding + triger 110 (80 newer discounted) + cylinder gasket 35-40 lira + felts 15 lira engine master takes between 100-150 TL to make them. As I said, if there is crack or melting on the roller paper. If there is no problem, you can handle 200 -250 lria .. hopefully it has been descriptive ..
08.05.2020 15:44 # 7
tilbe307
They can also fit through the oil filter while installing it.
08.05.2020 15:44 # 8
metin
You better put your photo.
I think he avoided the eccentric seal. fat may appear everywhere but how low is your level do you measure
08.05.2020 15:44 # 9
freedom206
The level has fallen from 2 to 3 at the maximum in the bar.
08.05.2020 15:44 # 10
freedom206
In the evening I will take it to the master, if not, I'll take pictures.
08.05.2020 15:44 # 11
metin
we are waiting,
08.05.2020 15:44 # 12
freedom206
I showed it to the master, he cleaned the top of the engine with a spray. Then he looked at where the oil came from, said it was from the injectors. He said that the injectors should be adjusted. Actually I didn't understand anything. What could oil leak with injectors have to do ??? freedom206 2011-06-30 21:10:15
08.05.2020 15:44 # 13
Is it oil or diesel you see?
08.05.2020 15:44 # 14
freedom206
Hmmm it looked black I thought it was oil, when I first took it they said engine oil in the journeymen but the master asked for fuel consumption. Apparently diesel is throwing ... I'm confused very well Confused
08.05.2020 15:44 # 15
taskin
There is no such thing as oil leaking from the injectors. There is a hose between the oil sump, the top cover, the bidet at the bottom of the turbo between the turbocharger and the engine. I think there are curved pipes after the diesel filter, diesel oil may leak from there or I saw the leak from the injector records in my own vehicle. is it primarily oil or diesel? you have to see it.
08.05.2020 15:44 # 16
ismail ozdemir
I had it in me when we changed the terrier, we changed the times and it was cut but it was not too much in me if it swelled like sweating
08.05.2020 15:44 # 17
MUTU
T
08.05.2020 15:44 # 18
MUTU
Hello: When you come to the place where your vehicle is parked after a while, does it leave black oil on the floor?
08.05.2020 15:44 # 19
Hagen
They are running away from the engine studs, they said that my vehicle will hurt the engine at 307 service. I took it to another master, put the left stud loose plastic washer and tightened it again, then cleaned the car with 4 pads of engine engine squeak
08.05.2020 15:44 # 20
jetma
Yes, teacher, there are black oil drops in an area as much as hand palm.
Page : / 2
