Oil Leak Problem 106
08.05.2020 21:21 # 1
Autku
https://hizliresim.com/nloj05
Next to the engine that appears, the black floor is greased and there are traces of oil where I parked
I have such an oil leak problem in my vehicle, what is the estimated problem and the cost?
the Autk 2019-10-31 01:55:12
08.05.2020 21:21 # 2
bilo131
the part in the picture is the rocker cover. he's probably missing his seal. The seal is 100 TL with 100 TL.
08.05.2020 21:21 # 3
talip206
Gasket you can buy and install something cheap yourself. It holds the two screws. There is nothing to be afraid of. But it starts to miss again after a year.
08.05.2020 21:21 # 4
x571
[QUOTE = talip206] Gasket you can buy and install something cheap yourself. It holds the two screws. There is nothing to be afraid of. But it starts to miss again after a year. [/ QUOTE]
I have that same problem. How do we do the tightening when installing the cover. Does it have a torque? Or did you squeeze like a quarter turn full turn.
Is there anything to consider when removing and installing it?
08.05.2020 21:21 # 5
talip206
[QUOTE = x571]
No torque, no screw is going to end when it comes to an end. The screw was like a blind nut already.
