Oil Leak
08.05.2020 21:06 # 1
peugeot55
Good day for a long time, there is oil leakage in my car. The gasket needs to be changed. So I went today and asked. Gasket + labor cost 120 TL.
08.05.2020 21:06 # 2
talip206
Probably the rocker door gasket (upper door gasket) you call a gasket. There is a price of 30 40 TL. You can even disassemble and install it yourself. It won't even take ten minutes. I changed it myself. It holds only two screws. I think even 20 30 pounds. But if the gasket is not original, it starts to sweat and leak again after a year.
Sample gasket
08.05.2020 21:06 # 3
x571
[QUOTE = talip206] Probably the rocker door gasket (upper door gasket) you call a gasket. There is a price of 30 40 TL. You can even disassemble and install it yourself. It won't even take ten minutes. I changed it myself. It holds only two screws. I think even 20 30 pounds. But if the gasket is not original, it starts to sweat and leak again after a year.
Sample gasket
What happens if the rocker gasket does not change
08.05.2020 21:06 # 4
talip206
So it depends on the state of the leak. It usually makes very little reduction from oil change to change. Maybe about a quarter of a tea glass.
It is only a cosmetic problem, a little greasy and right-handed. I think there is no other problem
