Oil leak
08.05.2020 17:13 # 1
sarpedon
My vehicle 2001 206 1.4xr. I pictured the oil leak that I noticed this morning, I wonder if you can help.
08.05.2020 17:13 # 2
Bugra
the gasket bursts, it turns yellow in between. it does not leak the seal change.
08.05.2020 17:13 # 3
sarpedon
I wonder if it creates a very serious problem, there is no serious loss of oil, and if it costs a lot, I ask for a period of time to handle me.
08.05.2020 17:13 # 4
hsnsnl
cartel seal, if I think it is full, my teacher .. it will not exceed 60-80tl.
08.05.2020 17:13 # 5
Serkan
My kidnapper from Carter gasket, there is no problem, I traveled like this for two years, he never missed it, after stopping the car, after the oil was landing on the oil pan, he missed 3-5 drops, we pulled the cartter together with my master, we put the black silicone back on it, we put it back, we did not miss a drop of oil for 3 years. & nbsp;
08.05.2020 17:13 # 6
cinar87
check the top of the engine as well, may come in the oil filter (especially use original oring in the filter)
08.05.2020 17:13 # 7
cgty86
sump gasket is missing, friends said no problem but I think it is a big problem, it starts to flow more with time, then you go into a pit or rub it somewhere, the sump falls down, the engine remains oil-free, etc.
08.05.2020 17:13 # 8
soneroo
I also agree with the friends above, it does not cause any problems, but you should check the oil level occasionally.
08.05.2020 17:13 # 9
sarpedon
When I went to ask for a price to calculate the cost today, it stated that there is no crankcase gasket instead of liquid gasket. Is the particle correct? Isn't this a special gasket?
08.05.2020 17:13 # 10
Serkan
Yes, as I wrote above, my teacher is applying a substance like black silicone, and I applied the same substance.
08.05.2020 17:13 # 11
pierson
where I park the car there is a little black liquid at the bottom of the engine. today i realized it too ... i guess i have oil leak in my car ... what should i do
08.05.2020 17:13 # 12
plawert
You need to have it checked and tested by having the oil leak
08.05.2020 17:13 # 13
My friend, I took care of the same problem on Thursday.
the leak was from the same place. The problem was from the crankcase fluid seal.
now its time is up.
I have 207 1.4 trendy. The 2008 model is at 33.000 km.
When the vehicle entered the
rod setting, I went down and looked.
immediately took the road of a good service.
the crankcase is dismantled. After dismantling, it goes to a car wash and is cleaned with diesel oil. After the carcass is cleaned, old worn liquid gasket is scraped on it, then the gasket applied parts of the crankcase are grinded with a motorized sandpaper. Spray itself at 15 TL.
würth brand 250 C durable liquid gasket is applied. 2o TL tube.
then the sump is reassembled.
if the discharged oil if it's worse, change it too.
I did that. 5w 30 magnetec 4 LT oil-würth liquid gasket and labor cost a total of 150 TL.
maverick 2013-04-27 00:50:42
08.05.2020 17:13 # 14
pierson
[QUOTE = pierson] where I parked the car, there is a little black liquid at the bottom of the engine. I realized that today ... I guess there is an oil leak in my car ... what should I do [/ QUOTE] I took the car to the
master today ... the master said he does not have a problem ... he said as much as a couple of drops .. but to me it is not 5 or 6 drops of water, but to me I am looking at where I parked ... I see ... he said it was a very laborious job to do ... it takes a day -and He said it would cost 500 TL .. He did not say that silicon fala or adhesive is applied like you ..
08.05.2020 17:13 # 15
samet206
the leakage of oil does not come into consideration, it is not costly things. These are not me. You will save yourself from staying there.
08.05.2020 17:13 # 16
pierson
500 TL said to the master ... Isn't it too expensive? I change oil every year, I will give 500 TL better
08.05.2020 17:13 # 17
samet206
[QUOTE = pierson] 500 tl said the master told me ... isn't it too expensive?
08.05.2020 17:13 # 18
pierson
What would be the complete oil pan opened? Is it a complete daily job?
08.05.2020 17:13 # 19
SDYMZ
I think there is no steel enclosure below. show you a few places as soon as possible, it doesn't hold much, there is a lot of benefit in the bidet extractor or engine protection.
08.05.2020 17:13 # 20
rolandgarros
It is useful to have a crankcase protection for the past and I think I will get it done as soon as possible.
Page : / 2
