oil lamp stops flashing
08.05.2020 19:56 # 1
Yagiz ali
I have a 306 gti to everyone, it's been four months since I started to have troubles. If you have information that is stating as it is done, I would be very happy if it helps, I would take it to two places.
08.05.2020 19:56 # 2
Yagiz ali
Bidet vehicle is warming up quickly, the vehicle is running ten minutes later, the temperature is 90, after a little stop, 100 is running, the fan is always working, I am stationing, the fan stops after ten minutes after the vehicle is stationed, I am glad if anyone knows how cool I got from the vehicle.
08.05.2020 19:56 # 3
firstly welcome. Is there a lpg in the vehicle. The sound coming from the bus is having the last days of the side pad related to the press pad or the bearing has failed. oil condition reduction etc. in the vehicle Is there. stopping may be related to the throttle-spark plug-coil-petrol filter-gasoline pump at the first start. I think the masters you go to assume you are masters. I would like to have the fan incident checked. They will advise the master for Istanbul friends.
08.05.2020 19:56 # 4
Have an oxygen sensor check.
08.05.2020 19:56 # 5
Yagiz ali
Soner Sağol master printing, I just changed the bata, unlike no sound du du gearbox started to make a sound after changing, I said that I got it to the master I made the clutch cut off the pressure to the clutch, he said it did not have anything to do with us. It has changed, so the problems came out, I cooled down, I get out of the car every day, the oil lamp is flashing, the fan stops ten minutes after the engine stops, after the engine works like a fire, after ten minutes, now the smell of gasoline started to come from the vehicle.
08.05.2020 19:56 # 6
Yagiz ali
When Soner Bidet Temperature is 90 times or 100, does not it require double fan operation?
08.05.2020 19:56 # 7
The printing changed with the pad, as well as on the chassis. most likely, the master is eating a halt while wearing it. 92-93 opens the first stage Around 105-110 second stage is activated. the smell of gasoline makes you control a smoker. Actually, I would like to clean the sockets of the customers on the vehicle with a contact spray.
08.05.2020 19:56 # 8
Yagiz ali
Okay thank you
