oil lamp problem
08.05.2020 16:14 # 1
famekontor
CUMMAL SELAMINALEYKUM AN APPROACH & nbsp; WEEK BEFORE MANY FROM MY VEHICLE DROP OF OIL EC that FARKEDERSEN I INDUSTRY FRIEND TAKE've OIL FILTER CHANGE I SAID OIL FILTER REMOVING were BUT PROBLEMS ENGINE THAT the CANTASI SAID AND CHARGES 350 per AROUND HOLDER his SAID AND FLOWING OIL TEMPORARY SOLUTION FIND I SAID AND OIL FILTER his CHANGING ORDEN ÇIKTIKD AFTER ROAD way FARKETTİM that OIL LAMP vehicle status by oN GAS LIGHT TOUCH with BACK FLASHING BENDE MAKE SURE tO YESTERDAY OTHER MASTERS Liked TAKE AND sTATUS SHOULD CHANGE AGENT'S OIL Musuri of I hAVE tO EXPLAIN total cost of labor + PARTS $ 100 AROUND TUTCAG the SAID AND WE GAVE the PART SİPAİRŞ Sender CHANGED BUT OIL LAMP LIGHTS FLASHING was electrition to TAKE we & nbsp; THE RESISTORS THAT DID DIFFERENTLY SAID THE LEGEND, they said that they would order them accordingly, we did so and tomorrow we are waiting for the piece to come, but a point that comes to my mind is that I am really a malfunction, or I am surprised by whom I believe that the oil lamp light started when I dismantled the oil filter when I went to the first master, Thank you very much for your help in advance AlbaYDemircaN 2011-10-13 20:06:43
08.05.2020 16:14 # 2
Engin Tepe
First of all welcome, Knowledgeable friends will help.
Let's take care not to use big fonts in the Forum You have noticed that you are writing big articles but it's late :)
08.05.2020 16:14 # 3
famekontor
Thank you for your big post warning, I noticed later :) but I opened the subject and introduced myself before
08.05.2020 16:14 # 4
Has the second master lifted the tool and looked at it? Has he examined the engine part?
If you order the vehicle according to the chassis number of your vehicle, you will be sure that it is 100% original and you will not tire your mind with such resistance issues.
08.05.2020 16:14 # 5
Engin Tepe
[QUOTE = famekontor] thank you for your big post warning later I noticed :) but I have already opened the subject and introduced myself [/ QUOTE]
& nbsp;
& nbsp;
Okay, I couldn't see it, it was seen when I looked carefully :)
08.05.2020 16:14 # 6
Even if I don't want to confuse you, it may be reasonable to change the oil from the crankshaft felt. It went down to around 30 to 40 liras, but the workmanship is quite expensive.
08.05.2020 16:14 # 7
famekontor
or its current stopped but the oil lamp lights up when the vehicle stops and writes a stop at the bottom and goes out when it touches the gas lightly
08.05.2020 16:14 # 8
I came to mind all sorts of scenarios such as oil purse and oil pump. Show me the sound of a master like a man, not to shake your engine. 13 20:26:26
08.05.2020 16:14 # 9
famekontor
:) the sender has changed, but thanks to the grinder, he had looked at the chassis number he had asked for wrong, but the resistances were different & nbsp; I hope we wait 2 more days, it is not another problem
08.05.2020 16:14 # 10
I hope you use your vehicle with peace of mind.
08.05.2020 16:14 # 11
famekontor
thank you very much my friend for your attention god bless your sentence
08.05.2020 16:14 # 12
zavur
Friends how many liters between the two lines of this dipstick?
