OIL LAMP + HAND BRAKE + STOP LAMP AT THE SAME TIME
08.05.2020 19:40 # 1
arlens
Hello friends My Problem with my Peugeot 206 1999 model Xr When the car warms up, when the temperature indicator appears, the Oil lamp and the Hand brake lamp AND STOP start to light. When I press the gas, the lamps go out when driving. The Oil lamp and the Hand brake lamp start to light up again when I stop at idle. This problem occurs after the engine is warming up. My first start does not give any warning when the engine is cold. Best regards
Arlens 2016-02-23 11:30:59
08.05.2020 19:40 # 2
First of all, we would appreciate if you introduce yourself from our welcome members. When it comes to the problem, there is an oil level sensor, there may be a problem, but the parking brake lamp comes on, there is a parking brake switch and have it checked. I suspect a battery and a charger will come to my mind, voltage imbalance.
08.05.2020 19:40 # 3
arlens
The problem has been resolved. The cause improved after the Fat Sender changed. I hope the friends with the same problem will help.
