oil lamp and stop warning
08.05.2020 20:03 # 1
horoz28
Hello friends, on Saturday, oil lamp and stop lamp are burning unintentionally under 1000 cycles ... There is no problem above 1000 cycles.
1.5 months ago, I changed the filters, bought the oil filter from bosch, because it is not the orig, it happened again, someone searched and learned on the internet, another friend said brake fluid, what do you think is the problem?
08.05.2020 20:03 # 2
Selox
My brother. I had it too. He was flirting. Oil pump changed, improved. This piece in the crankcase. One day, the car becomes a guest.
08.05.2020 20:03 # 3
erendumlu
Replace your oil and oil filter.
Take your oil in the appropriate fineness. Org your filter. received. It happened, it did not, the crankcase will open and the oil pump will be replaced. Oil pressure is low.
