oil lamp
02.09.2022 17:37 # 1
kalafat
Hello friends ; I had my vehicle, which I have been using for 4 years, had its routine maintenance done 1 week ago, when I finished it and pressed the starter, the oil lamp came on, by the way, it goes off when the revs increase
. The problem was not fixed, anyone have any ideas?
While there was no problem for 4 years, why did it occur as a result of maintenance, of course, it may have come across by chance (master used 10/40 oil)
After that, I asked a few different masters and they said that the engine had to come down, I wonder if there is a place you can recommend ?
02.09.2022 20:02 # 2
talip206
Hello, if the oil is fake, it may turn on the light.
The oil filter is also very bad in the market.
In general, these two cause problems
02.09.2022 21:32 # 3
kalafat
Thank you, is there a place you can recommend on the Anatolian side of Istanbul?
04.09.2022 19:09 # 4
talip206
Kadosan D Blok No 28 Boğaziçi Automotive Ali Usta is an expert on peugeot vehicles. It also has original devices.
11.09.2022 17:54 # 5
kalafat
Friends, be sure to read
After all the above-mentioned processes, I took the vehicle to a service in Kartal Sanayi, where it was stated that the engine should be lowered and revised. As a result of all the operations, an invoice of 26.750 TL was issued, but the problem still persisted; then the original oil filter block, located just below the oil filter, was installed and the problem was finally solved! Not to mention all the torment I've suffered and my money gone! I wanted to share it in case it might happen to other friends
11.09.2022 17:58 # 6
kalafat
thank you very much, i wish i could see it, i wish i went to the place you said i wouldn't have 10 days and my money :(
11.09.2022 17:59 # 7
kalafat
Thank you very much, I just wish I could see it, I wouldn't have had 10 days and money to take it to the place you said :(
11.09.2022 19:53 # 8
bulutes
While changing the oil filter, the nozzle of the filter did not fit into its socket, it broke while tightening it, so I had a problem, so I replaced the filter and the problem went away.
