oil indicator lamp + stop
08.05.2020 14:15 # 1
The "oil indicator lamp + stop" lights on the instrument panel lit together. As soon as I turned it off, I immediately switched it off again. Dil Çıkarma ) did not improve .. of course I checked the oil .. the level is full .. even the indicator is correct during the start .. before 10 seconds, "oil indicator lamp + stop" lamp starts blinking with an audible warning .. .. I thought it was going out anyway, I said, I continued on the road, it never burned, until the lights stopped .. I thought the level of idling, "oil indicator lamp + stop" lights appeared on the panel .. I gave gas again went out .. I came to the house and parked, I called the master but I could not reach .. I said stop, let me ask friends from the forum .. Is there any diagnosis?
08.05.2020 14:15 # 2
trtolgi
a few months ago it gave the same error in my car. my wife used the car (you guess how you used it). oil indicator and stop. They said that they detected leakage in the gasket where the cartel bolt was located.
08.05.2020 14:15 # 3
I changed oil a few days ago, of course with the oil filter. I think it was after that .. now I look at what is written on the right and left and there are diagnoses from oil pump to customer. I hope it's just the filter.
08.05.2020 14:15 # 4
hasimayaz
you have a problem with the filter or oil pump.
08.05.2020 14:15 # 5
behzat
may be from the client
08.05.2020 14:15 # 6
thanks guys..at least the idea has been created .. i am planning to see the result by changing the oil and filter in the first place .. if it does not improve, the sender and the pump will be the next stages.
08.05.2020 14:15 # 7
300yedi
I have oil for oil, but the indicator sometimes shows full level, sometimes it shows one level, but the oil and stop light does not light up.
08.05.2020 14:15 # 8
[QUOTE = 300 seven] I have oil on the cubicle, but the indicator sometimes shows a full level, sometimes on one level but the oil and stop lamp are not lit [/ QUOTE]
heh yours sender here .. zamazingo bi nev-i sensor called sender .. if it is broken it causes wrong display. like this gas tank's float is broken .. of course this is my opinion .. it is also necessary to show it to a more experienced person. I will change the oil filter. ufukyus 2010-05-16 00:53:41
08.05.2020 14:15 # 9
trtolgi
ufukyus Kardes.If you want to put a big piece of cardboard under the car.
08.05.2020 14:15 # 10
I had parked in a clean place yesterday evening. Thanks for dinner. Göz Kırpma I do not give any chance to oil dripping work anyway .. it is useful to review all the details
08.05.2020 14:15 # 11
hasimayaz
[QUOTE = ufukyus] thank you guys..at least idea has been created .. i am planning to see the result by changing the oil and filter in the first place .. if it does not improve then the pump and the pump will be the next steps. [/ QUOTE]
Do not overuse the vehicle in this way. If it is caused by an oil pump, it may cause serious damage to your engine.
08.05.2020 14:15 # 12
I just caught the master .. he said we are changing the filter on Monday. 206 in the k.peder did the same problem. it was after the oil filter and oil change. The master was also looking at the kpeder's car. I am more comfortable now .. said that it will not be a problem to move to the service. of course the first job is to take the vehicle to the service .. ufukyus 2010-05-16 14:42:49
08.05.2020 14:15 # 13
[QUOTE = ufukyus] I just caught the master .. we are changing the filter on Monday said. 206 in the k.peder did the same problem. it was after the oil filter and oil change. The master was also looking at the kpeder's car. I am more comfortable now .. said that it will not be a problem to move to the service. of course the first job is to take the vehicle to the service .. [/ QUOTE]
if the problem is solved by changing the filter; friend, I will say that you can not handle this filter, apparently, you can not do it .. so the 206 occurrence of malfunction in the same way. Sleepy
08.05.2020 14:15 # 14
Yes, friends who are stuck with the oil filter 15 TL. I came to work in the morning for 10 minutes, master. changed the filter. the problem is not visible at the moment .. I left it at idle for quite some time, the fault lamp did not come on.
08.05.2020 14:15 # 15
bestfear
My oil filter has become abnormal after my friends change the oil filter and oil .... According to the car's oil bar, the normal indicator sometimes falls on its head and sometimes shows full ... I think it is from the customer ... Can you replace an ordinary repairman? Or is it necessarily a service? ...
08.05.2020 14:15 # 16
[QUOTE = bestfear] Friends after changing my oil Filter and oil, the oil gauge has become abnormal .... The normal indicator for the car's oil bar is sometimes falling off one on one and sometimes showing full ... I think it is from the client ... you? Or is it necessarily a service? ... [/ QUOTE]
It is the same in all of us. The fact that the ground on which your vehicle is located is not even, causes it to be wrong. It is necessary not to be fooled by the most beautiful indicator and to check the oil periodically using the oil bar.
08.05.2020 14:15 # 17
sercinho
[QUOTE = koliva] [QUOTE = bestfear] Friends after changing my oil filter and oil, the oil gauge has become abnormal .... According to the car oil bar, the normal indicator sometimes falls to one on one and sometimes shows full ... I think it is from the customer ... Can he replace an ordinary repairman? Or is it necessarily a service? ... [/ QUOTE]
[/ QUOTE
] as well, I don't understand if that indicator is working properly, I don't understand if the brother is showing properly or not, I don't understand it anymore.
08.05.2020 14:15 # 18
It's not broken, you get it done. Its so natural Kahkaha
08.05.2020 14:15 # 19
bestfear
This means that you shouldn't be too tired ...
08.05.2020 14:15 # 20
uslucihan
Hello friends, the same problem exists in my vehicle, the filter and the oil switch has changed, but it has not improved yet again it gave the same error.
Page : / 2
