Oil indicator
08.05.2020 17:12 # 1
uyarrr
The level in the oil indicator of my friends car was like the picture below ... & nbsp; I looked through the engine & nbsp; Add 1 liter & nbsp; ettrdirm. & nbsp; The level started to show a minimum ..
Why does this happen?
& nbsp;
It was in this state before adding oil. now minimum ..
08.05.2020 17:12 # 2
KenBlockJR
why did you add oil already finished? it will recover after a while.
08.05.2020 17:12 # 3
uyarrr
why did I add & nbsp; They said the indicator would not be safe. & nbsp; I looked out of the oil cube as well.
I completed 1 liter .. now the indicator min. says :)
uyarrr 2012-12-10 18:59:12
08.05.2020 17:12 # 4
Serkan
Min. Then 6 lines (_ _ _ _ _ _) appear on the screen and flash?
08.05.2020 17:12 # 5
sansasyon61
the indicator is misleading I passed my morning last night, i got the hair, got it looked at the master, he said the level of oil was full then he corrected himself :)
08.05.2020 17:12 # 6
uyarrr
has improved today max & nbsp; came spontaneously
08.05.2020 17:12 # 7
uyarrr
now the indicator & nbsp; a & nbsp; min. & nbsp; & nbsp; a max & nbsp; show & nbsp; He was amazed
08.05.2020 17:12 # 8
fatihgg
The car park changes according to the level of the place you are sadly :) Most of the 307 users come to the press, always check with oil.
08.05.2020 17:12 # 9
error
the subject is old but problem baki: D
friends always show me one tooth, is there a sensor of this sensor? Where is it?
08.05.2020 17:12 # 10
error
up ..
08.05.2020 17:12 # 11
leffe
the oil level sensor is broken and the new one is around 60-70tl if I don't know it wrong. Most of what you see on the net is & nbsp; oil pressure sensor. Do not mix around 20 TL. (I mixed it from there I know)
08.05.2020 17:12 # 12
cocomo
If you parked in a somewhat inclined place, your oil flowed in reverse when the oil was hot .. warning from him ..
you test it on flat ground I don't think you will have any trouble.
08.05.2020 17:12 # 13
emre_akdag
the saint of the indicator in me
08.05.2020 17:12 # 14
SDYMZ
The exact solution is to guarantee that the dipstick is guaranteed when the engine is cold in the flat place.
08.05.2020 17:12 # 15
error
Thank you for your answers, friends, I said that I would ask for this issue for a long time, even though the oil stick is always my reference in the car park on a flat surface :)
08.05.2020 17:12 # 16
nevce
my person is not the same problem just look at your nickname bar
