oil indicator
08.05.2020 17:04 # 1
pt206
When I turned the ignition to start the car while returning from work with my friends today, it says max on the oil gauge and the indicator was flashing. Does this mean that there is too much oil in the engine? Also, what does it mean to do this after using this time? It has been 3-5 months since the oil was changed.
08.05.2020 17:04 # 2
Depending on the vehicle's parking position, there may be such disruptions to the digital display. However, you should still consider this warning and observe the situation from the oil bar. In oil cubes, if the level is above the maximum, it is necessary to intervene. Likewise if it is below the minimum. If the level is normal, you can ignore the digital display.
08.05.2020 17:04 # 3
pt206
let me check this out right now
