Oil in fuse box
08.05.2020 21:14 # 1
aSeydioglu
Good evening / mornings. I had a temperature problem last year. After a lot of advice, I was told to open the sigorts box and check the fuse. When I opened and removed the box, I saw that the fuses were in oil and I noticed that a fuse was blown. This insurance was also the insurance of the last stage of the fan. When the fan is not turning on while driving uphill in hot weather in the village, the car was on the screen, showing a fake temperature and turning off the engine. The fuse was not the box was cleaned, the problem disappeared. But last week, I did stop and get up in the heat, too, and again the temperature of the fan must have turned 130 at a time of 90+ degrees I realized that something happened again in the box. I opened the fuse box again. I showed it to 1-2 places, they said steering pump failure. They started from 700 to 1,500 TL. steering fluid dropped below the minimum. Oil was walking through the cable through the pump. Approximately 1 year, the level of insurance will be burned or contactless. I ask for help from master friends / brothers / sisters who know the idea, the mechanic method. Thanks. & Nbsp;
08.05.2020 21:14 # 2
How is the oil through the cable to the fuse box is really strange. If you are on the European side, there is a union auto Özay Çelik master, they highly recommend him. If you search on the internet, I will call you and say a view.
08.05.2020 21:14 # 3
aSeydioglu
Yes, I'm on the European side. Where you say I will go as soon as possible. It really seemed strange to me
