Oil in 307xr cooling water
08.05.2020 18:19 # 1
tegote
The same subject may have been opened before, but my trouble is a bit more than that
My vehicle is a 307 xr 2005 model lpg li. Thanks for your help in advance
About 2 weeks ago, I noticed oil droplets in cooling water, I started to give service to antipolution fault warning. I went to the service. had covered the air inlet and had a gas outlet. I immediately went to the workshop and left the car. All seals, felts, coils, spark plugs, timing set filters, whatever you can think of, I renewed everything, and I said that I would not bother again, but when I woke up in the morning, I smelled a gas again and when I opened the hood again, there is oil in cooling water and what is related to gas leakage is related to each other. shows up at the same time.
However, the problem that everyone has had stops when I wasted. I have been reading the forum for 2-3 days. I saw that everyone was having trouble with these problems, and I have an extra gas problem at the same time. I took it to a few masters, they all say the same things, says gasket, says the cooling system, but I have already reset it all. I will be very happy if a friend who can say this is my solution comes out.
1-There is oil in the coolant
2-It stops continuously and the vehicle runs hard in the morning, idling is too low
3. LPG leakage starts at the same time when oil is mixed with water. (Lpg Atiker and I took it for 6 months to check it. No problem. Gas leakage occurs when oil is mixed with water.)
08.05.2020 18:19 # 2
kuscu38
I recommend you to look at the temperature of the coach, you probably burned the gasket, otherwise it is impossible to have oil in the radiator, or because of the antifreeze, if there is a small amount of oil in the antifreeze, but if the lpg brain is freezing and pulls the foot out of the gas, it is most likely that you burned the gasket. I suggest you go to the biker as soon as possible ...
Try it, if the vehicle is running smoothly on the gasoline, the answer I said without wasting the intermediate seal in the right seal ...
08.05.2020 18:19 # 3
tegote
I changed the gaskets last week, the top cover was removed, the broken crack was done. All the tests were done. They said it was either cracked or burnt. They said no problem. They said from the cooling system.
08.05.2020 18:19 # 4
muhammed.ceyhan
If there is oil, the gasket was burned in the water, teacher.
