oil from unknown origin
08.05.2020 21:10 # 1
yenipejocu
Have a nice day today. I figured out the oil leak from the gasket. the masters say the gearbox or the transmission sender is not on the left. The oil comes from the table.
Bidet spinning fluctuation stop problem could not be solved.
08.05.2020 21:10 # 2
There is a leak from the oil axle seal on the table there, my brother is dripping from them. What kind of operations did the top for idling?
08.05.2020 21:11 # 3
yenipejocu
throat butterfly cleaning calibration lpg gas adjustment.
the master said he made a mistake + - in their throat butterfly.
said a thousand passes in gasoline.
there was no problem like this
08.05.2020 21:11 # 4
I have a friend in the same vehicle as your teacher. As far as I can remember, the 1.4 16v engine is knitted in these engines because the throttle production is faulty. You have to look at your vehicle, as your master said, if there is a + - pole error, it is probably defective.
08.05.2020 21:11 # 5
yenipejocu
There was no such error after the first cleaning and gas adjustment.
When it comes to saying that the gearbox must be removed in the oil, the oil does not come from there, the left wheel comes from somewhere.
