Oil dripping
08.05.2020 16:24 # 1
serommm
First of all hello everyone.
I put the car down the ramp at night. When I came to ride in the morning, oil dripped under the car. I opened the inside, there was oil in the protection sheet below. There was an abnormal level of oil reduction. I did not understand the man I put down the ramp just this oil dripping. Where is the malfunction and this oil reduction. My car explodes in Ankara. 306 griffe 98 model.
Thanks in advance ..
serommm 2011-11-29 12:30:31
08.05.2020 16:24 # 2
___KxL___
First of all, it is important where the leakage is. It can be from the carter, it can be from the oil filter, it can be from the & nbsp; axle seal.
08.05.2020 16:24 # 3
serommm
My drip dropped from where the front right wheel was. So the place that drips is to the right of the car.
08.05.2020 16:24 # 4
___KxL___
Then it's probably the axle seal sister. I think the price of 10-15 pounds felt. If the transmission oil is too low, the bidet oil costs, but it is not so much if you only realized this day.
08.05.2020 16:24 # 5
serommm
There was a drop, but I noticed the dripping today. I have only a lot of protection sheet below.
Apparently we have to go to a good master.
08.05.2020 16:24 # 6
___KxL___
The master I went to is `` Yilmazlar Peugeot '' - Engin Usta and Ibrahim Usta Ivedik Organize Sanayi on the 1546th street. I am very pleased that you can go with peace of mind from the master.
08.05.2020 16:24 # 7
serommm
[QUOTE = ___ KxL___] The master I went to is `` Yılmazlar Peugeot`` - Engin Usta and İbrahim Usta İvedik Organize Sanayi on the 1546th street. I am very pleased that you can go with peace of mind from the master. [/ QUOTE]
Thank you bro, thank you for your help.
08.05.2020 16:24 # 8
06OzGuR06
If I am not mistaken, there is a sump plug on the right side. It may be missing from the cap.
08.05.2020 16:24 # 9
Ucyuzalti
I was suffering from the same problem, that is, oil dripping underneath the vehicle, they said they are missing from the axle seal. i1110.photobucket.com/albums/h454/zavur/04032010264.jpg "border =" 0 "/>
Üyüzyüzaltı 2011-11-29 19:48:28
08.05.2020 16:24 # 10
Ucyuzalti
In the operating manual, it writes 500 mg reduction to 1000 km max. Of course, in this gasoline, LPG messes up the mess "LOL" same tool I have lpg 1000 km & nbsp; 400 mg is decreasing, but it is obvious from exhaust as it does not exist in gasoline. I always buy gasoline to use in gasoline. Start looking for your question, the leak in the simplest places. Meanwhile, the oil reduction of the car is not an abnormal situation at certain levels. The reason that the gap between the piston and the cylinder leaves a certain level of gap in the new generation of vehicles while the factory produces a little oil, but the friction and abrasion die, therefore the oil is reduced. it is normal. The oil that does not darken in the same way compiles well, because the room does not function if the wrong oil does not darken, the blackening oil is good because it darkens because it is working "Thumbs
ÜÇyüzaltı 2011-11-29 20:12:32
08.05.2020 16:24 # 11
serommm
Well, the friends stood down on the ramp where the friends dropped it. I put it on the flat ground at night, not a single drop.
I think there is a leak somewhere. The engine is not burning oil. When I asked my motor master friend, they said that there is no problem with the engine of the vehicle, the engine of the vehicle is very fresh and beautiful oil burning. There is an oil that Shell produces for Gas vehicles. I use it. 15 40. Oil master recommended this. I don't know, are we bad?
serommm 2011-11- 30 15:13:41
08.05.2020 16:24 # 12
06OzGuR06
Why do you use 15W-40 if the car does not burn fat.I think which oil is recommended in the catalog.I think 10W40 is better.But the decision is yours.
08.05.2020 16:24 # 13
serommm
My teacher lpg car. I didn't get it from him. I did not understand him. Obviously, he fits him. Normally, he suggests 1040 oils of total peugeot.
08.05.2020 16:24 # 14
06OzGuR06
Since the thermal efficiency is low in LPG, it seems that the circlips cannot expand enough, so it may be missing from the circlips and the amount of fat burning is increasing. oil may decrease.
LPG & nbsp; for vehicles with oil (15W40) & nbsp; If it's okay, continue to him.
08.05.2020 16:24 # 15
serommm
[QUOTE = 06ÖZGÜR06] Since the thermal efficiency is low in LPG, it seems that the circlips are not expanding enough, therefore, the oil burning amount may be increased by missing the circlips, this oil may have been put in order to prevent this because there is a decrease in the performance of the vehicle. May reduce oil at 10W40 after 15W40 oil.
LPG & nbsp; for vehicles with oil (15W40) & nbsp; If it is appropriate then go ahead.
Thank you, sir. Thank you for your interest.
08.05.2020 16:24 # 16
repropark
Oil producers for lpg vehicles produce oil special to lpg, it is useful to try.
08.05.2020 16:24 # 17
serommm
Hello friends, I went to the industry today.
They said that the cylinder head will be opened, throwing the oil out of there. But they said power steering may be missing oil. from where the malfunction is. >
Let's look at the market.
08.05.2020 16:24 # 18
Ucyuzalti
Ask a few more masters, die from here, if you don't miss it, you would be wasting your brother
08.05.2020 16:24 # 19
serommm
I showed it to 2 masters, 2side said the same place, one of them gave 600 mlyn price, one of them gave 400,400 friend already.
Reviews
08.05.2020 16:24 # 20
djchaos
Clean the engine thoroughly, lubricate the parts where you think that you missed the oil first, make a definite determination. I took it to the master, he kept 80 TL, the shock absorber upper wedges changed.
Page : / 2
