oil drain
08.05.2020 19:50 # 1
akyuz.cagri
Hello friends. I use 1.4 hdi. My car is constantly leaking oil. On average, 10 thousand km decreased by 2 liters. I filled the oil last week and the oil was completely drained in a week. the oil was draining from the coolant, we took care of it, but now there is still leaking as before. The moment I stop the vehicle, 2-3 drops of oil accumulate on the dry ground, do you have any ideas?
08.05.2020 19:50 # 2
gergerli
So my teacher, this car should be lifted on the fiber and the man should look at the reason for the smart leak.
08.05.2020 19:50 # 3
Deniz44
The standard one is the oil cover, where the oil filter is placed, the plastic is covered, it is likely that the purchasing industry is 50 TL high probability flowing from the teeth.
08.05.2020 19:50 # 4
Gilan
the same problem is that the contamination of me started leaking oil from the bottom plate, if I have time, I will make a break after draining the oil
08.05.2020 19:50 # 5
akyuz.cagri
First I bought the car, friends, the plugs are obsolete, said the master, it cost 100 lira, I like the master, everyone becomes an industrialist, but it is hard to find a master ...
08.05.2020 19:50 # 6
Gilan
I have now looked at 1 crankcase 2 grank goats 3 oil pump oring 4 complete leakage around the oil filter why do you think
08.05.2020 19:50 # 7
ssakyel
Excessive oil may have been added when changing oil, or they threw too thick oil.
