oil drain?
08.05.2020 17:57 # 1
onur07
I park my car, after stopping for about 3-5 hours, the oil is dripping in the size of the steering wheel at the level of the left front wheel, what could it be? There is no shortage of engine oil and what other oil should I check? 206 hdi x-line 2004 model
08.05.2020 17:57 # 2
samet206
Could it be gearbox oil?
08.05.2020 17:57 # 3
kuscu38
Check the firen hydraulics and steering oil if you say it is not in the engine oil.
08.05.2020 17:57 # 4
onur07
I looked at the steering oil a little diminished, completed it, there is no missing in the brake oil, it seems to be complete, there is no normal reduction in the engine oil.
08.05.2020 17:57 # 5
soner09
gearbox oil control, bolted in the section where the left wheel flows from there
08.05.2020 17:57 # 6
ekinoks44
The gearbox oil is mine and the seals that I was missing should be changed. I think the vehicle needs to be lifted in the fiber for its control.
08.05.2020 17:57 # 7
sezar206
If it is missing from the gearbox, check it to a master, you can complete it. Never mind your hand.
08.05.2020 17:57 # 8
TaZ
The gearbox has a drain right there, and since they put too much oil in the car for days, when the oil coolant went down to its normal level, it started to not vomit anymore.
08.05.2020 17:57 # 9
onur07
Thank you very much for your help ... There is nothing to do other than looking at the service.
08.05.2020 17:57 # 10
fthusl
in my car is missing from the right side, probably I will change the gasket when I change the oil from the crankcase Unhappy
08.05.2020 17:57 # 11
onur07
Oil flow and transmission oil, obviously, we neglected aka let's say it's over, do you have a big problem? You kidnap little, if I complete it all the time?
08.05.2020 17:57 # 12
kuscu38
Hodja, if you don't have very difficult materials to complete the gearbox oil yourself ... but if the gearbox oil is missing, the car will sound like a beating from the engine. or the gear does not pass, there will be trouble ...
