Oil change oil information
08.05.2020 17:08 # 1
bysonic
Friends, I have a 206 cc 2002 model vehicle, and the changed oil I bought in 158 thousand is now in 167 thousand. Some say that every 15 thousand, some say only when the oil gets dark twice a year. I think I have to put Castrol 5/40, I don't know it clearly either. When my oil change came, the man I bought said change every 10 thousand. castrol edge is normal castrol is what is the difference? & nbsp; I am someone who does not know much about the young vehicle, because the car is sports, even the master in the industry draws a price according to his head. My right door window was problematic I couldn't even make it, I took it to 3 masters 6. & nbsp; industry etc. I would be glad if knowledgeable friends give information about oil change. Is there any need for oil additives etc? I have a lot of questions in mind, I am reading a lot of topics in the forum whenever I find the opportunity. & nbsp;
08.05.2020 17:08 # 2
KenBlockJR
It is important which oil has been put into the vehicle before. but since its mileage increases, you can put castrol magnatec 10/40 - total quartz 10/40 or mobile 10/40
08.05.2020 17:08 # 3
bysonic
castrol said 10-40 I put it, but it was written on the paper, the license is not next to me.
08.05.2020 17:08 # 4
KenBlockJR
If it's 10/40, just continue.
08.05.2020 17:08 # 5
Serkan
Continue to 10/40 in my opinion, you can use castrol magnetec, change the oil as 10 thousand km or 1 year
08.05.2020 17:08 # 6
bysonic
Or 10 years a year? & Nbsp;
08.05.2020 17:08 # 7
Serkan
10 thousand km after the last oil change, or 1 year (whichever comes first), I'm throwing change your oil that you have done 10 thousand km in 3 months, or you have made 3 thousand km in 1 year ...
08.05.2020 17:08 # 8
Mami86
Hello, when the subject was opened, 1.4 hdi 94000 km of my car I bought today changed in 87000 oil. I was using the mobile, I had read the previous owner but the full synthetic castrol edge 5-40 was recommended, I can not remember in the forum alone for diesel or gasoline. What is your suggestion for diesel vehicle?
08.05.2020 17:08 # 9
bysonic
10 thousand km is filling naturally: D I make 3 thousand km a month on average. 10 12 15 what kind of damages will happen if I do a little more km, r
08.05.2020 17:08 # 10
Serkan
[QUOTE = Mami86]
Hello, when I opened the topic, 1.4 hdi 94000 km of my car I bought today changed in 87000 oil. I used to use the mobile, but I have read the previous synthetic castrol edge 5-40 is recommended. It was 82 thousand km. I don't know what the previous owner used. When I first bought it, I used 10/40, then I passed 5/40 as a brand. & Nbsp; I use castrol edge If the oil does not decrease, I would recommend 5/40 to you engine works quieter and more comfortable
08.05.2020 17:08 # 11
bysonic
What is the difference between 5/40 and 10/40?
08.05.2020 17:08 # 12
Mami86
thank you for your suggestion Serco05 I think I will get 5-40 & nbsp; I am waiting for the salary & nbsp; as we know, we gave the car whatever it was in the palm .. :)
08.05.2020 17:08 # 13
Mami86
These numbers 5-40 and 10-40 indicate the viscosity (fluidity) of the oil. The first number is the low temperatures and the last number is the viscosity value of the oil at high temperatures. 5-40 thinner oil with folk expression .. & nbsp; If there is oil leakage, it is better to choose thicker oils if you have a motor or a high mileage vehicle.
08.05.2020 17:08 # 14
bysonic
[QUOTE = Mami86] 5-40 and 10-40 these numbers indicate the viscosity (fluidity) of the oil. The first number is the low temperatures and the last number is the viscosity value of the oil at high temperatures. 5-40 thinner oil with folk expression .. & nbsp; If there is oil leakage, it would be better to choose thicker oils if you have a motor or a high mileage vehicle ... [/ QUOTE] & nbsp;
It was a very descriptive answer. thank you for your attention. Well, if there is a normal castrol or castrol edge joke, we will fix it in 10/40 and if we put the name of the oil, it will be better if we put it in 10 thousand financially difficult & nbsp; I think it will find 11 12 thousand.
08.05.2020 17:08 # 15
Mami86
In other words, although I am not sure I want to give wrong information, castrol edge I think it is full synthetic oil ... if you ask what the difference is & nbsp; I wondered if ftam synthetic oil is obtained by using more & nbsp; advanced chemical treatment.
