Oil Change (castrol, mobile or total) |
| 08.05.2020 14:16 | # 1 |
| 08.05.2020 14:16 | # 2 |
Long Beach |
total-mobil-castrol, these are premium motor oils, do not use oil that you have not heard of. Continue to tolerance. |
| 08.05.2020 14:16 | # 3 |
Onur |
castrol mobil petronas these 3 are the best oils
| 08.05.2020 14:16 | # 4 |
BuRCaK |
I use Total. there is no problem. they are all equivalent in some way. It is not worth considering that much.
| 08.05.2020 14:16 | # 5 |
[QUOTE = Long Beach] total-mobil-castrol these are premium motor oils, do not use the oil you have not heard of. Continue to the tour. [/ QUOTE] I agree with Yaşar master, do not put the oils you just heard in the car, I think the life will be less .. Peugeot Total recommends. but Castrol can also be taken. |
| 08.05.2020 14:16 | # 6 |
I'm using total, I'm glad 4 liters 35tl I didn't have any problems
| 08.05.2020 14:16 | # 7 |
muhlisoz |
I am thinking of changing the oil in 5w-10w style stuff. I use the 2005 model petrol 206 on the oil, which one should I buy? I don't know. See exposure. Not to know, after all, is it a shame not to learn? |
| 08.05.2020 14:16 | # 8 |
BuRCaK |
If it is gasoline, take 10-40.
| 08.05.2020 14:16 | # 9 |
muhlisoz |
If [QUOTE = BURÇaK] is gasoline, get 10-40. [/ QUOTE] Thank you, my brother ... |
| 08.05.2020 14:16 | # 10 |
BuRCaK |
When you buy it, you will be healthier. You're welcome.
| 08.05.2020 14:16 | # 11 |
Which oil is put in 308 hdi. 90% of the oil is used. Is the service only using total castrol? I used castrol in my previous vehicles and I was very satisfied.
| 08.05.2020 14:16 | # 12 |
I HAVE A FRIEND WHICH WORKS AT THE PEUGEOT AUTHORIZED SERVICE, WE HAVE CHANGED THE OIL BEFORE THE PEUGEOT TOTAL BUT IT HAS TOTALLY TENDED WITH THE TOTAL AND I HAVE MOBILE MOBILE AND I HAVE MOBILE I HAVE MOBILE, I HAVE MOBILE, I HAVE MOBILE, I HAVE MOBILE, I HAVE MOBILE, I HAVE MOBILE, I HAVE MOBILE, I HAVE MOBILE MOBILE.
| 08.05.2020 14:16 | # 13 |
mobil is very good oil. Expensive ... then I say castrol. I no longer put a total vehicle. I even put the castrol in the service. The men made Naz but they did. ![]() I don't get a total anymore. |
| 08.05.2020 14:16 | # 14 |
castrol magnetec.
| 08.05.2020 14:16 | # 15 |
I will not put the tatatal again. What will I heat with another oil while the mobile is standing ... the pug for the total French product is making it inconvenient. otherwise it is not because it is very quality. Indeed, there is an oil in a total that I have not seen in Turkey. It shows in the list and only writes in France. Quartz model is sold in Turkey ...
| 08.05.2020 14:16 | # 16 |
sercinho |
mobile is the best quality I know in these oils, I know it is because it is total french as your friend says it is used in French. If you are not going to be a good oil, I would like to add a boron additive to my skin.
| 08.05.2020 14:16 | # 17 |
voodoo |
mobile and yacco brother .... these two are the best
| 08.05.2020 14:16 | # 18 |
I use Castrol too I'm very satisfied
| 08.05.2020 14:16 | # 19 |
We use Castrol EDGE 0-30 in 307 1,4 HDi, we are very pleased.
| 08.05.2020 14:16 | # 20 |
I have never had a problem with the oil of mobile extraordinary pleasure.
