Oil change at the fuel station
08.05.2020 20:04 # 1
herry
Greetings friends,
Some fuel stations have oil and oil filter exchange locations. For example, the last time I saw it in Shell, you buy Shell Helix HX7 1040 oil for 90 TL, we change it right away. It looks like a practical solution for those who just want to have an oil change. However, it is recommended that we do not use total oil for our peugeot. Did you change oil in such places, or would you recommend pejo oil that Shell uses?
08.05.2020 20:04 # 2
When the brother changes oil, you should definitely change the oil filter. shell hyundai is using authorized services If you recommend you to use different brands of oil, if you put total, continue or castrol will get an extra oil filter 10-15 tl is 105 tl. If you take it as a set, you will give 20 TL of workmanship as in the link I provided. 125 TL will be changed in complete filters. Meanwhile, many of the oils at the fuel stations may be out of date. I suggest you pay attention. In addition, you can get 10 TL more castrol magnatec 10w / 40.
good forums.
https://www.peugeotturkiye.com/peugeot-206-1.4-benzinli-1999-2003-filtre-seti-orj
sonerkyl 2016-12-14 15:29:57
08.05.2020 20:04 # 3
herry
[QUOTE = sonerkyl] When the brother changes oil, you definitely need to change the oil filter. shell hyundai is using authorized services If you recommend you to use different brands of oil, if you put total, continue or castrol will get an extra oil filter 10-15 tl is 105 tl. If you take it as a set, you will give 20 TL of workmanship as in the link I provided. 125 TL will be changed in complete filters. Meanwhile, many of the oils at the fuel stations may be out of date. I suggest you pay attention. In addition, you can get 10 TL more castrol magnatec 10w / 40.
good forums.
your suggestion made more sense, thank you,
If I go to a master with these materials, 20 wouldn't want more than 30?
Also, the link you provided is RSH sponsored by our forum, is it familiar?
herry 2016-12-14 15:38:23
08.05.2020 20:04 # 4
If you want more than 20-30 TL, I recommend that you pass by the door of the master and get a price first, any master will easily change it. Well, if I have materials in my hand, I will make a special 10 TL campaign for the forum, open a stopper for oil change for a maximum of 10-15 minutes, and also disassemble the oil filter.
08.05.2020 20:04 # 5
ekinoks44
The guy who checked the oil in gasoline said the guy said that the oil was missing, looked really under the line, said good add I said it takes 2 Lt, I said 2 it comes too much, I said put it, but still the oil came up to the top of the line. I mean, gas stations are trying to sell excess oil.
08.05.2020 20:04 # 6
talip206
Shell's 10w 40 oil already starts from 49 lira on the internet, including cargo. (Knitted epttavm site) The guys are already adding extra oil change extra at the station.
