OIL CHANGE AND OIL ADDITIVES
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 20:58 # 1
Ugurcan57
Good day everyone had a little change in my car's oil change before, I used castrol and opetin 10 / 40W oils, but for some reason it was not satisfying me or psychologically, my car seemed as if it was not working easily. Apart from these, this product caught my attention
The reason for my attention to this product is that my car works in the morning hours, when it is cold, more loud than normal, this disturbs my nerves. Will this product cure my problem or I am also open to other suggestions that you can recommend to me :)
08.05.2020 20:58 # 2
These are the brands that are among my priorities in oil brands. motul - liqui moly - mobil These three brands have always been my choice. I have been using motul in my car for two maintenance. There was no problem. When it was gasoline, the engine is silent. once you used the additive you said, but I did not feel any change, obviously, maybe when there is a gasoline vehicle, there may be a change in the sound of your vehicle. Of course, if you are going to buy this additive, I recommend using it with the same brand of oil.
08.05.2020 20:58 # 3
Ugurcan57
There was a little misunderstanding in my profile from me, the second vehicle of the house is writing, now I realized that the vehicle I mentioned is 406 D8 engine petrol lpg
08.05.2020 20:58 # 4
HasGur
I have used the oil appearing in the test for years on diesel engine vehicles. It is very good and cheap in terms of protection. If you search the youtube channel on the link, many oils have been tested and compared.
EK: Manufacturers do not recommend adding any substance to their own oil, engine oils it contains the necessary additives.
[TUBE] apyxchjıerm [/ TUBE]
Hasgör 2018-07-25 17:09:37
08.05.2020 20:58 # 5
x571
[QUOTE = HasGur] I have used the oil appearing in the test for years on diesel engine vehicles. It is very good and cheap in terms of protection. If you search the youtube channel on the link, many oils have been tested and compared.
I wish that if our people do such tests, if we watch it in our mother tongue or make use of it.
08.05.2020 20:58 # 6
HasGur
[QUOTE = x571]
Unfortunately, it is impossible for consumers to change their oil a few times a year. There is no job in our industrial trades, the purpose of the sharing minority is to do the works that are mandatory in the workshop environment without giving details. Attract customers by sharing them with sketchy images! However, after a small investment , hundreds of tests can be made in a year and a perfect archive can be created by separating up to 10cc of different oils brought by customers (even the amount remaining at the bottom is sufficient) .
