Oil change
08.05.2020 21:24 # 1
Eren”FS”
Hi guys, I have a 407 Executive 1.6 hdi 2009 model car. My first car is so I want to pay attention as much as I can. Oil change came the oil you suggested and also I would appreciate if you write the things you say change as well. I am also using my car in Cyprus. Is there anything you want to use fuel for this? Thanks
08.05.2020 21:24 # 2
iso0625
Hello there. I have the same vehicle. My advice as oil Motul X-clean 5w30 EFE. If the fuels are dirty, always replace the diesel filter. On my vehicle was Delphi HDF939. Always use the original or products of original equipment manufacturers such as Mann, bosch, mahle in all of your filters. At high km, egr, egr pipe and intake manifold cleaning make the vehicle comfortable. I will do it soon. As far as I know, the degree of air conditioning Max and min. It should not be used in order not to break the claps. Set the degree you want and press auto :)
08.05.2020 21:24 # 3
iso0625
Hello there. I have the same vehicle. My advice as oil Motul X-clean 5w30 EFE. If the fuels are dirty, always replace the diesel filter. On my vehicle was Delphi HDF939. Always use the original or products of original equipment manufacturers such as Mann, bosch, mahle in all of your filters. At high kms egr, egr pipe and intake manifold cleaning make the vehicle comfortable. I will do it soon. As far as I know, the degree of air conditioning Max and min. It should not be used in order not to break the claps. Set the degree you want and press auto :)
08.05.2020 21:24 # 4
Eren”FS”
thank you for your interest. I plan to put castrol 10w-40 as it is too hot for oil change. Total suggests in the booklet of the car but they say castrol is better
08.05.2020 21:24 # 5
whisky
I have been using 5-30 mobil 1 since two oil changes. I had no problems.
whiskey 2019-12-27 09:18:59
08.05.2020 21:24 # 6
iso0625
[QUOTE = Eren ”FS”] thank you for your interest. I plan to put castrol 10w-40 as it is too hot for oil change. Total suggests in the booklet of the car, but they say castrol is better [/ QUOTE]
5w30 is recommended for our vehicles. I don't know how 10w40 is. Personally, I wouldn't use it. Knowing friends help.
08.05.2020 21:24 # 7
Eren”FS”
Correctly recommended oil says 5W30 synthetic total but if you have the car maintenance card 26. On the page there is a graph called "Oil value according to ambient temperature values". I subtract 10w40 oil from this value hodja
08.05.2020 21:24 # 8
kilic1923
castrol edge 5w30 fully synthetic 10w40 I know that there is no full synthetic.
08.05.2020 21:24 # 9
[QUOTE = kilic1923] castrol edge 5w30 fully synthetic 10w40 I know that there is no full synthetic. [/ QUOTE]
There are brands that are very expensive
08.05.2020 21:24 # 10
kubi 73
original oil total 5/30, this oil provides all the requirements of the engine
