oil capacity
02.02.2023 22:05 # 1
gokhan050
Friends, I have a 2006 model 1.4 petrol vehicle. When I change the oil, the master pours all 4 liters. I don't understand this job. I wonder if my vehicle is filled with too much oil? Also, 10w40 is always added. It is stated in the booklet that 5w40 should be put in. Will I have any problems when I return to 5w40?
03.02.2023 10:49 # 2
arifbsrn
hello sir. When you look at the
castrol site, your oil capacity is 2.75 liters as you said.
but I have read that 3.5 - 4.5 liters of oil is ideal for 4-cylinder engines.
For example, I have a 1.4 206. With 3.5 liters of oil, the dipstick level comes to the ideal level.
Adding 4 liters of oil to your vehicle may be too much (about half a liter). ). Be sure to check it from the bar on flat ground.
There may be a minimum oil requirement of 2.75.
10w40 Using oil is generally preferred in vehicles with high KM (for more than 100.000 - 150.000). /div> arifbsrn2023-02-03 10:50:26
04.02.2023 07:48 # 3
Berkay Erdinc
Your vehicle is tu3jp 1.4 8v, most likely the oil capacity is 3 liters and it has an oil filter capacity of 0.3. If the old oil is drained from your vehicle at a rate that will not remain at all, it needs 3.3 liters of oil. You may have looked at it. Even if it takes 2.7 or 3.3, anyway, too much oil is put in your car, I think, change your master. They are popular. They put 10w40 in every vehicle. Why is it so much preferred? If we compare 10w40 oil with 5w30 or 5w40 in general, if
10w40 is a semi-synthetic oil in general, it is cheaper.
Also, the vehicle They say that it should not burn oil, put thick oil, and most of the time, users prefer 10w40 for these reasons.
But do not use 0w30 or 5w30. If 10w40 oil is used in the vehicle that needs to be hung, since the spaces between the parts are compared to 0w30 or 5w30, 10w40 oil enters these gaps more difficult, so wear is more. Also, depending on the quality of the oil, semi-synthetic oil evaporates more in the face of temperature than fully synthetic oil. If there is no malfunction, more oil will be reduced, and the oil will be more dry. This institution covers everything from the inside of the engine to the crankcase ventilation, the intake manifold and the throttle.
But you can use 10w40 oil in your vehicle. Pay attention to the amount from the dipstick. Check it out.
Over-added oil can break the sealing of the o-rings, seals and gaskets in the engine due to the increase in oil pressure and this pressure will cause oil leaks just because of this
10.02.2023 04:35 # 4
talip206
According to the owner's manual, the oil capacity of your vehicle is
3 lt excluding oil filter
3.25 lt with oil filter.
13.02.2023 00:02 # 5
gokhan050
Thank you very much for your answers guys.
Apparently it's a problem to put all 4 liters. That's what I guessed. I'll pay special attention from now on.
13.02.2023 00:05 # 6
gokhan050
px; color: rgb0, 0, 0; font-size: 14.6667px; table-layout: fixed; margin: 10px 0px;">
My car is listed as a 1.4 16V et3j4 engine. Are the standards still the same?
https://forum.peugeotturkey.com/quick_topic_search.asp?TID=52132" class="dropDownTopicSearch" frameborder="0" scrolling="no" rel="nofollow" style="font-size: 14.6667px; text-align: -webkit-center;">
