office cleaning price
05.10.2021 22:29 # 1
Bayer
Called from the service center today. The engine had to be cleaned of soot, and for this the upper cylinder head had to be removed. This process starts from at least 6-7 thousand TL. With the condition of the engine and the extra costs, it could possibly go over 10 thousand TL.
I do not have the financial means to afford it at the moment. The price seems too high to me. Is it normal? How much further can the vehicle travel this way? If it is very unhealthy, will I burn the engine completely?
Is there a reliable place in Istanbul where I can get this job done cheaper?
06.10.2021 07:49 # 2
antipollution
first time i heard it bro. What was the problem? When you pull the dipstick, is the consistency of the oil close to extremely solid? It's normal for it to be black, don't look at it, but is the consistency fluid? Look, for example, the engine was overheating. My master had the catalyst and egr cleaned first. Then it's the top cover but not the top cover, that is, the cover with the gasket. He opened it and looked at it while cleaning it and said, "Your engine is good, your nation is becoming like tar" etc. He cleaned it well, put new oil and sealed it 8 months ago. It hasn't been a problem since then. I think, instead of spending money on the service, consult a well-known master near you, brother. We have a lot of complaints about the services here as well. I was going to go to the first timing belt change, so that it was guaranteed, when I heard the complaints, I changed it to the same master. By the way, my car is at 185 thousand
06.10.2021 12:50 # 3
Bayer
The vehicle may rev erratically when idling. from time to time, it stops by shaking right after the ignition is turned on. As a warning, the engine warning lamp comes on.
08.10.2021 09:15 # 4
antipollution
hmm needs to be investigated, there are many reasons to do this. The important thing is to find the right master and not to find the mistake in the wrong place and to be able to pinpoint the unnecessary expense.
09.10.2021 09:48 # 5
emirksk
Is the vehicle connected to the computer? As you said, there is no method, they looked for a place to pluck goose.
09.10.2021 22:11 # 6
sozuak
Such a method and expense for such a complaint. I heard first time. Research well. That much money is not given.
I am giving an example, there is a part called the idle motor. This part controls the air entering the engine when the throttle is closed. If it gets dirty with dirt from the crankcase ventilation and air and reacts slowly, your complaints will arise. First of all, this part in the throttle body must be cleaned and lubricated (it is also wrong to leave it without oil with brake lining spray). If it's too bad, I think you should start by replacing it and cleaning its slot.
