odors in the ventilation
08.05.2020 14:15 # 1
trigger
friends when I run the ventilation of hello206 without pressing the air conditioner button, there is a bad smell, whether there is air inlet or recirculation from the outside. smell disappears when the air conditioner operates. pollen filter has been replaced 2 weeks, what do you think is the problem?
the smell, as if you entered a slightly humid environment ...
let's 2010-05-25 00:22:27
08.05.2020 14:15 # 2
hasimayaz
radiator may have mold. Squeeze some smell into the pollen filter will improve. hasimayaz 2010-05-26 10:54:54
08.05.2020 14:15 # 3
trigger
Thank you, Mr. Sir. let's try
08.05.2020 14:15 # 4
coyote26
I have the same problem with me. Thank you.
08.05.2020 14:15 # 5
BuRCaK
I have the same problem. my radiator radiator Hashem?
08.05.2020 14:15 # 6
shamed
Where is the pollen filter war?
08.05.2020 14:15 # 7
trigger
One of the familiar masters today pointed out some places under the steering wheel and said the honeycombs should be cleaned. There is also an air conditioner disinfection of the body. Let's start with what he says brain, it made sense
08.05.2020 14:15 # 8
ayerkar
http://www.hepsiburada.com/productdetails.aspx?categoryid=26001&productid=otm090150
I recommend this product. it is easy to apply and it works and it is cheap.
08.05.2020 14:15 # 9
BuRCaK
[QUOTE = Ayer is]
I recommend this product. it is easy to implement and works, and also cheap. [/ QUOTE]
  • Usage :
  • Insert the product hose in the vehicle or in the ventilation grilles of your home and office air conditioners by stretching it.
  • (Except on-tape ventilation grilles on vehicles)
  • Do I need to apply my other grills?
    08.05.2020 14:15 # 10
    ayerkar
    [QUOTE = vetch] [QUOTE = Ayer is]
  • Usage :
    I think they have made a note because they are afraid that the liquid that can leak from the grids on the tape will reach the tape. I removed the tape and applied it to 4 grids (2 on top + 2 on the right and left ends). If you don't want to struggle, you can apply it from other grills.
    08.05.2020 14:15 # 11
    hasimayaz
    [QUOTE = shamed]
    There is a small sponge rather than a filter. on the right side under the wiper motor cover.
    08.05.2020 14:15 # 12
    Onur
    206's demi in the same place
    08.05.2020 14:15 # 13
    BuRCaK
    [QUOTE = Ayer's] [QUOTE = vetch] [QUOTE = Ayer is]
  • Usage :
    I ordered the same day and applied it today. we squeezed half of my own car in half of your friend BMW 316 ti compac. Really the smell is gone. But since it is the first day, it gives a heavy fresh scent. That smell decreases to 1-2 days. The vehicle is now closed with 4 doors closed and the smell is stacked into the morning, but the result is for your information.
    08.05.2020 14:15 # 14
    BuRCaK
    [QUOTE = hasimayaz] [QUOTE = shamed]
    Where is my 206 pollen filter? Do you have a scheme or something?
    08.05.2020 14:15 # 15
    hasimayaz
    [QUOTE = BURÇaK] [QUOTE = hasimayaz] [QUOTE = shamed]
    08.05.2020 14:15 # 16
    BuRCaK
    Nobel prize should be given to you. Or you should buy Peugeot R&D or something Sırıtma
    Tşkler ..
    08.05.2020 14:15 # 17
    Onur
    Thank you, brother
    08.05.2020 14:15 # 18
    trigger
    using the product mentioned only causes us to smell another, I thought it would not eliminate the dirt
    08.05.2020 14:15 # 19
    BuRCaK
    Using the product mentioned [QUOTE = trigger] will only cause us to smell another smell, I will not remove the dirt, I thought [/ QUOTE]
    Perfume deodorants already have this logic. If you don't feel bad smell and make you smell nice, I think there is no problem. It is claimed that it cleans bacteria and fungi in the product description. Whatever she does, the bad smell is gone. I think it's free for 6 TL.
  • It is ideal for cleaning the A / C System and eliminates bacteria and fungi and prevents its formation for a long time.
  • It is effective in removing fungal bacteria and other harmful microorganisms in ventilation ducts and condensate ducts.
  • It eliminates bacteria and fungi, which are harmful for health and cause bad odors, and prevents their formation for a long time.
  • Vetch 2010-06-06 09:54:11
    08.05.2020 14:15 # 20
    trigger
    I ordered the product you recommended. But when the air conditioner works, I smell it. smell comes if the air conditioner blows off
    Page : / 2
