Odor inside the vehicle
08.01.2023 13:00 # 1
Gokhan 1717
Hello friends, I just joined you. I have a 2008 model 1.6 vti 308 vehicle. There is a situation in the car, when the engine is warming up at 70 degrees or something, when you turn on the windshield defogger, it smells like a burnt lining for a while, it smells like a poison, but then it passes, it doesn't happen at 90 degrees, it starts when it gets hot, then it cuts off, I thought it was the clutch lining, I just changed it, it's interesting. side does not work in the summer, so it does it in hot blowing, it does not in cold blowing, I couldn't get out of the work, I would be very happy if you could help me. Thanks in advance
12.01.2023 12:30 # 2
whisky
Does the smell you mentioned in the first run also come when you open the engine hood? When was the pollen filter last changed?
15.01.2023 01:08 # 3
Berkay Erdinc
Hello
If the brake pads smell, have the brake centers checked. One or more of the pads may be stuck.
On the other hand, I'm telling you because you say it smells like brake lining, so if it's not a lining smell, it may be an odor stuck to the pollen filter. Or the heater core may have changed before. It has been seen many times before that when the heater cores are heated, the heater cores emit such different odors when they are heated for the first time.
/div>
21.01.2023 12:26 # 4
Gokhan 1717
We found the problem, it may happen to you, I thought I'd write it for your information. Oil drips from the oil filter log on the exhaust, the smell of burning oil comes out, the smell goes away after the oil is burned. Thank you for your interest.
