Odometer falls ... stress begins.
08.05.2020 20:16 # 1
Brcbyrktr
Good day friends ..
My problem, which has not been sounding for a while, is more frequent, but it is again hose down. During normal cruising, the mileage bar suddenly drops to zero and there is a contraction in the towing of the car. .The contraction of the car is interrupted. When I say trigerdi swings, the hole has grown. I can't go to the service right now. Do you worry about my head? I would be glad if anyone knows and gives ideas.
08.05.2020 20:16 # 2
onlycihan
I am wondering if there is a sensor that detects and measures the mileage and vehicle speed. Does it give a bad signal to the brain, but the car starts to contract
08.05.2020 20:16 # 3
Peugeot35
spark plugs are in trouble, so it kicks and when it kicks, there is a fall in km.
Buying from bosch spark plug. If you have a spark plug wrench, you can remove it and check it.
08.05.2020 20:16 # 4
Brcbyrktr
If I knew ... it was like something was clogged and then reopened ...
08.05.2020 20:16 # 5
Brcbyrktr
When I asked the spark plugs when changing the triger in the service ... he said they have no spark plugs, they said they had a spark plug ... when they said there was a problem with them .. no problem they said ... did not shake me or do not. How can I tell you ... imagine that you pedaled to get on the bike and tighten the brake a few times so as not to stop the bike. Brcbyrkt is 2017-03-29 00:01:38
08.05.2020 20:16 # 6
Selox
If km falls, 90 percent speed sensor. There is no problem when you change it. It is normal for him to do it when the indicator fell because he had me too. Sometimes even an airbag burns. Selox 2017-03-29 08:03:02
08.05.2020 20:16 # 7
alperen1414
If [QUOTE = Selox] km is falling, the 90 percent speed sensor. There is no problem when you change it. It is normal for him to do it when the indicator fell because he had me too. Sometimes even an airbag burns. [/ QUOTE]
This problem also exists in my vehicle. Where is the speed sensor. How do you know a fees?
08.05.2020 20:16 # 8
KILIC
I think your vehicle is diesel. There is no spark plug, so the service is just right, there is only a spark plug. It can be from the speed sensor.
08.05.2020 20:16 # 9
A few of my friends said: "Turbon have a long life for you" .. Are they right? Turbo malfunction is happening friends?
08.05.2020 20:16 # 10
KILIC
If there is a problem in Turbon, the vehicle will have difficulty in passing 3 thousand revolutions, and the vehicle also becomes strange.
08.05.2020 20:16 # 11
outlaw
outlaw 2017-03-30 12:31:58
08.05.2020 20:16 # 12
burch1975 2017-03-29 15:19:37
08.05.2020 20:16 # 13
JunioR56
Take sandpaper of 1 pound and make sure that the battery terminals and battery cables are clean well and if the battery cables are not tightened with wrenches, squeeze the latch as much as you can. When the flow of electricity is not smooth, it occasionally makes errors.
My vehicle does not calculate the abs, esp, handbrake, power steering, the road you go at km 0, the vehicle's course was changing.
I did what I was talking about. I'll try.
08.05.2020 20:16 # 14
talip206
It sounded like a battery to me. I would only say that if the pointer falls, the engine is defective or the wheel is broken. But misfire etc. The battery usually comes out when the problems are together. The battery may have completed its life.
08.05.2020 20:16 # 15
JunioR56
Don't think like you're done. The pole head and cable ends do not oxidize and oxidize electricity over time, and the vehicle protects and shuts it down to prevent damage to the brain. From time to time, it fails on its own and gets back on its own.
Before you take it to the master and grab money, clean it with sandpaper and try to tighten it well.
08.05.2020 20:16 # 16
Gokcesel
The chronic problem of 206 occasionally occurred in my vehicle. Gas responses were changing as you said when you traveled for miles. It is likely to be from the speed sensor or the motors in the gauge. The turbocharger is not a problem with the battery, this was my both sound :)
08.05.2020 20:16 # 17
Peugeot35
[QUOTE = Peugeot35] spark plugs are in trouble, so it kicks and when it kicks, there is a drop in km.
I thought gasoline was yours.
If strange noises are coming during the saddle misfire, it may be from the turbo. My friend said that we had a problem with diesel in this industry.
If you think the problem is from the cruise control, try it as well by connecting it to your brain and disabling cruise control.
Peugeot35 2017-03-29 23:00:47
