Occense sensor and misfire mornings |
| 08.05.2020 14:57 | # 1 |
Friends pejeot 307 xt automatic series car I have and I have been facing a problem recently The lpg gasoline gives poor mixture line and I went to my service, they told me to check the lpg settings I went down to lpg and made a reset, they reset it completely, they reinstalled ecu yu gave the same error again today From now on, they made the spark plug change to the throttle, and for this mistake, the master said Gazcida, he said, he made the sensor, and he changed it at the same time. I have a 2 servicing service today, complete engine fuel system maintenance is necessary, said that the cost is very bad, bosh I know the master said lpg very often, the sensor of the oxygene is broken. If the lpg master says that the sensor does not fail without full deterioration, my poor or rich wife will fail and back again. I got back to my service, they tied it to pejeot software and they said poor mix, lpg carburetion setting, I went, I did the same as lpg, the man increased by 10, this time my rich wife went to another service, he said, rum has fallen and remains hungry the cylinder head will hurt 2 billion minimum goes he said I bought the car 18 found 20 with no expenses I think the valves came to the manifolt egsos timing circulation disc came 26 came, then lpg 27 found zero car :)) I came to my head, I went to a different day, I went to a service, the guy tied to the computer, I said to the computer, I did it from the sibobs, he did not say the master, he said, the master said he did it in the sibobs, when he pressed the gas, he throws it in the smoke, I do not think it from the exhaust, the lamp sensors are broken, I said, I saw the sensor, I looked at the exhaust, I saw the sensor, we looked at the sensor, I saw the sensor 0 it worked hot and worked very well that it was the first time in the morning, the smell of the gas that came out did not come out in the smell of the gas. said the master it smokes smoke from the sibob and the smell of the fuel oil comes in a little color, because it does not perceive the full heat because the smell of the gas does not perceive the full heat. and it is okay and the smell is not the same and the smell is not the same and it is normal if you use it if you don't read the lpg full net. respects:)) and the exhaust emits properly in emission, no sibobs, no emissions, no smell in emissions, and good bosh said bosh snow would not inconvenience the engine from sibob bosh car service |
| 08.05.2020 14:57 | # 2 |
Sorry my friend, how could I not understand this type of spelling as well :)) you have written like corba. it would be better if you use a few punctuation marks: D "No, I went and I came and said" this is a mixture of karman corman. I read the article with ıt. Where are you in Istanbul, let us help you in a way ... as far as I can tell from what you wrote alone, you met with unskilled masters of heat. no soot dust, no gas smell, no lpg smell etc. who shakes them like that. While reading, I also laughed at the same time ... they call the houses ... The duty of the oxygen sensor is not to "smell" the fuel, be crazy :)) The amount of oxygen in the exhaust gas emitted. Because look at the name "oxygen sensor". sends it to the brain at the value it measures. the electronical control unit is technic name is "ecu". According to this information, ecu also adjusts the air mixture we call afr. As a result, it provides maximum efficiency from the fuel burned by the engine ... it is a part that passes in the engine's operating system for a long time ...
| 08.05.2020 14:57 | # 3 |
I'm sitting in Istanbul pendik, tell the incident When I start the car in the morning, gasoline is a mild misfire and the smell of gas is this one. The lpg night with gas is falling and after the time the problem is corrected, but the LPG burning style is doing different trimming. I'm going to auto industry lpg he throws lpgci pejeot pejeot throws lpg :))) I did 10 thousand maintenance romano 3 months has been started to make the day after 10 thousand care But if it does in the gas, there is a calibration error, it doesn't do it on the gas, it does LPG. )) yesterday I was going on the road, lpg was low, the supply was not burning, let's rob my master lpg decreased full blade gave poor mixture error before finishing 1 sec later lpg otti took gasoline gave day fucking mistake and added it to the heat in my head my head is very mixed 1 month ago cc made after that, 10 weeks after maintenance, 10 thousand maintenance after that, then a mistake was made to be in the situation I came somebody says that the gas put the pump in the role, it can burn, it says the pump is lpg, if you put the pump in the role, the full gas can stop at lpg nights. somebody says put my role confused ..))) |
| 08.05.2020 14:57 | # 4 |
Your heat is mixed. only basic logic is water. First put the LPG aside and assume that it is absent. The vehicle must first work flawlessly on gasoline. If the gas does not work well, the lpg grandfather will not improve. but the presentation of the LPG and the combustion of the fire is different, but there is never any case. On the contrary, when it is properly adjusted, the engine runs better in LPG. If you say why the octane is high, no knock will occur and this means less vibration. Here is the one with the mouth talking. knowing, telling, not knowing, shaking, without support, fairy tale. If you shook somebody at you ... Anyway, let's come to simplicity. You say that I could not go to any place in that area and get any results. If you want me, I will be directed to my friend's service in Maslak. |
| 08.05.2020 14:57 | # 5 |
do you guess from the oxygen sensor ?? * |
| 08.05.2020 14:57 | # 6 |
of course you can ...
| 08.05.2020 14:57 | # 7 |
brother, I'm splitting up laughing, you're super cecoli .. if i ask you a question When should my car change the belt of 75bin 307 xr 1.4 petrol timing belt? |
| 08.05.2020 14:57 | # 8 |
PEUGEOT GASOLINE ENGINES ALL 80,000 KM DE TRİGER KIT REPLACES THE VEHICLE OF THE VEHICLE IF THERE IS THERE
