Obd device question
08.05.2020 21:06 # 1
Karacocuk24
I bought obd device from the internet in the night, everyone has a good day error code for learning etc, but the device does not fit the socket fully, the red light in it burns, but it is not connected to the phone, I put it in the fiat doblo, it is connected to the backup for 5 seconds. While the
My car 2001 model 206 xr
Karacocuk24 2018-12-20 11:17:25
08.05.2020 21:06 # 2
Can you take a photo? In addition to the vehicle's obd socket, some new obd devices do not support protocols of vehicles before 2004, so you may not be able to connect.
08.05.2020 21:06 # 3
Karacocuk24
[QUOTE = sonerkyl] can you take a photo? In addition to the vehicle's obd socket, some of the new obd devices do not support protocols of vehicles before 2004, so you may not be able to connect.
This photo
08.05.2020 21:06 # 4
maximusti
I can't see the photo, but vehicles before 2001 do not support obd2 protocol,
the device you received is obd 2 so it is not working.
08.05.2020 21:06 # 5
Karacocuk24
I cannot see the [QUOTE = maximusti] photo, but vehicles before 2001 do not support the obd2 protocol,
[/ QUOTE] is this only programmed called pp2000? And can we get this cable, install it on our own computer and use it?
08.05.2020 21:06 # 6
ismailkaya
Since the nail is not well done, it is hardly attached. If the red light is on, you will turn on the ignition and you will bring it to the starter position. torgue (lite) 3- there are obd connector programs 3. If you are going to use the program, the internet must be open.
08.05.2020 21:06 # 7
Karacocuk24
[QUOTE = ismailkaya] Since the nail is not well done, it gets harder. If the red light is on, you will turn on the ignition, you will bring it to the starter position and then you will connect to the device with the program you have installed on your phone. - eobd facile 2- torgue (lite) 3- obd connector programs are available 3. If you are going to use the program, the internet must be open. [/ QUOTE]
Well, I tried so much, I connect with bluetooth, but it does not get in touch with the car.
08.05.2020 21:06 # 8
ersin61
My friend does not support before 2004, as I know. It supports some of the 2004s and does not support some models. I experienced the 2004 event myself.
08.05.2020 21:06 # 9
Karacocuk24
I have tried 2 programs, unfortunately, obd is connected but it does not communicate with the brain. Until now, I can only tell you how to measure the temperature of the coolant without looking at the computer. I wonder if I hang in the store?
