NOT WORKING SIMILARLY
08.05.2020 19:54 # 1
ozkanerol
HELLO FRIENDS
WHEN I ROTATE THE CONTACT WHEN THE VEHICLE IS ON THE GASOLINE, THE PATCH IS SOUND AND STOPPED AS I SUCCESS. GAS PUMP HAS CHANGED NEW 2 MONTHS. PETROL FILTER HAS CHANGED 2 DAYS AGO. BUT SRUN CONTINUES. WHY COULD IT BE.
I DON'T KNOW THAT I HAVE A CONNECTION THAT HAS BEEN AFFECTED AFTER THIS PROBLEM ABOVE.
--- THE CAR HAS PROBLEMED. HARARET SEAL CHANGED TWICE
---- THERMOSTAT HAS CHANGED 5 TIMES (NO ONE HAS OPENED)
---- RADIATOR CHANGED
---- PERIOD HAS CHANGED ALWAYS
---- FAN CHANGED
---- FAN RESISTANCE CHANGED
---- RELAYS CHANGED.
HOWEVER I DO NOT OPEN THERMOSTAT AND I USE IT NOW THERMOSTAT WITHOUT HARM.
THERE WAS CHANGED IN THE TRIGER SET WHEN CHANGING AND THEN THERE ARE STARTING TO THE ENGINE. NO TROUBLE IN THE SENT OF THE CAR. BUT IT IS RUNNING WITH THE GAS THE CAR IS UNLIMITED BUT IT IS DROPPED.
I WOULD LIKE IF THOSE WHO HAVE VISITED ABOUT THESE TOPICS.
08.05.2020 19:54 # 2
First of all, welcome to us. Please don't use capital letters in accordance with our forum rules. When it comes to your problem, if it explodes, spark plug-coil-gasoline injectors - lpg regulator - lpg injectors - gas cutters - lpg heat sensor - lpg and gasoline map sensors should be checked and the throttle should be cleaned. one or more of these things may cause this. When it comes to the thermostat, it is a very strange event that none of the thermostats installed are originally opened. In a hot country like Antalya, the trouble will not open the cover gasket. The parts that are changed are original.
08.05.2020 19:54 # 3
Cyrus35
In addition, it may be torn in the exhaust manifold and show it to the exhauster, but when the soner writes, the main reasons are when the gasoline is in trouble, you can use the bottom of the tank as well as you can have the injector control on the plugs of dust and dirt injectors. Your gas pump has changed, may it be a situation such as not being installed correctly, or the covers are problematic, there may be a condition of making air should be checked.
08.05.2020 19:54 # 4
ozkanerol
The parts followed were original. The last anadol brand car thermostat was installed, but it did not happen because the water was running out. The fitting was siliconized but it did not. The water turns out to be normal when the fan turns 90 when the temperature is normal and the temperature is normal.
08.05.2020 19:54 # 5
ozkanerol
Thank you very much. I do not leave any gas under the tank halfway in the car.
08.05.2020 19:54 # 6
Well, if the thermostat socket has been checked, my teacher, maybe the thermostat socket is problematic, it may be a situation that prevents the thermostat installed from opening.
08.05.2020 19:54 # 7
ozkanerol
thermostat socket not checked. Five thermostats were tried, but three of them were original. But anadol thermostat turned on. It is an interesting situation, but I am very bored with this situation. At the same time, the car that runs on gasoline will not start. I will get to a service again and have it checked.
08.05.2020 19:54 # 8
Well, is there a situation like water reduction in the vehicle, the spare water tank cover has never changed.
http://www.peugeotmarket.com/peugeot-206-14-benzınlı-termostat-yuvası-orjınal,pr-940.html
08.05.2020 19:54 # 9
ozkanerol
No water reduction problem.
