not working in the morning and too much oil ??? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 15:09 | # 1 |
rapsody |
I had to press the starter 5-6 times to start my car this morning, it worked at the end, but it worked knocked down until the tachometer fell from 1200 to 800. It was idle, but when I gave gas at idle, it was not knocked. Also, the oil indicator started flashing a little earlier today.I looked at the guide, it was signaling because the oil was too much, but I did not add any oil. Are there any among you? |
| 08.05.2020 15:09 | # 2 |
I know that the light on the display is also caused by low oil pressure. So when you give gas, does the light stop?
| 08.05.2020 15:09 | # 3 |
rapsody |
I know it is lit when the indicator light is low, but it is blinking because it is too much.
| 08.05.2020 15:09 | # 4 |
rapsody |
up
| 08.05.2020 15:09 | # 5 |
rapsody |
up
| 08.05.2020 15:09 | # 6 |
rapsody |
gncl
| 08.05.2020 15:09 | # 7 |
rapsody |
Either your friends, I was embarrassed to update the topic: ((no idea, too much oil?
