Not Working at 406 Gasoline
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 20:13 # 1
emretolunay
Hello friends, I have my vehicle 1996 2.0 SV Zavoli Sequential.
1) My vehicle is working sometimes, sometimes it does not work, I also run it on gas and it works without any problem.
2) In LPG, the heat goes up to 100s, but if I can switch to gasoline, I will not get bored.
I'm waiting for your help.
08.05.2020 20:13 # 2
First of all, welcome emre bey. when it comes to your problems
1- The reason for not working in LPG directly and working on gasoline is that my petrol pump teacher has lost its function or is completely broken.
2-peugeot is running hot, even if you see 100, it is 97-98 degrees. If you want, you can change a temperature sensor. the front of the radiator is closed from dust and dirt. Never use without antifreeze.
08.05.2020 20:13 # 3
emretolunay
[QUOTE = sonerkyl] first of all welcome emre bey. when it comes to your problems
do not charge. If you want, you can change a temperature sensor. the front of the radiator is closed from dust and dirt. Never use without antifreeze.
Thank you, thank you. So what pumps are expensive for my car? What other cars do I have the idea of cheap? emretolunay 2017-02-28 11:47:00
08.05.2020 20:13 # 4
The original disability of my teacher may actually be only if you can find the engine, but it does not give me much efficiency. You can look at the exit, but how long it takes the room is not guaranteed. LPG vehicles are the healthiest way of trying not to drop it under the half tank which is caused by having less gas. because it makes the cooling of the pump gasoline. Have the petrol roles checked in my teacher, sockets can be oxidized.
sonerkyl 2017-02-28 12:34:53
08.05.2020 20:13 # 5
emretolunay
[QUOTE = sonerkyl] My original disability may actually be only if you can find the engine, but it does not give me much efficiency, unfortunately, I think it is important in your financial situation, but if you think my head does not hurt, I think 380 TL is not much. You can look at the exit, but how long it takes the room is not guaranteed. LPG vehicles are the healthiest way of trying not to drop it under the half tank which is caused by having less gas. because it makes the cooling of the pump gasoline. Have the petrol roles checked in my teacher, sockets can be oxidized.
I understand, hod, if the gas pump has a problem, I know that the car will not work at all, but my car is working in the gasoline.
08.05.2020 20:13 # 6
The problem is that the teacher works when the pump is cold. It deforms over time. This disrupts the pump. Unfortunately, the pump does not perform its full function. Of course they have to check the pump to make sure that fuel injection etc. Electricians check whether it performs or pumps intermittently or not at all.
08.05.2020 20:13 # 7
emretolunay
[QUOTE = sonerkyl] the problem is that my teacher is running when the pump is cold. It deforms over time. This disrupts the pump. Unfortunately, the pump does not perform its full function. Of course they have to check the pump to make sure that fuel injection etc. Electricians check whether it performs or pumps intermittently or not at all. [/ QUOTE]
Thank you very much hojam, whatever you say, if you have trouble, I will apply for your help again.
08.05.2020 20:13 # 8
you are welcome hodja good forums. we always wait, we try to help with what we know.
