not resolved! 2007 307 parking assistance faulty ha
08.05.2020 19:36 # 1
Faruk
hello masters
2007 307 sw 1.6 hdi premium car parking assistance faulty error appeared on my vehicle for the first time yesterday evening.
I stopped the car and started it in reverse gear, the screen came up, the sound came out, but again it gave the parking assistance faulty error and it didn't work again.
Then whatever I said, I continued, sometime the radio was turned off, it turned on, it sounded like pat.
I am waiting for the opinions and help of experienced friends.
I searched on the forum and on the net I couldn't find anything.
I saw people with sensor malfunctions and those who were constantly kicking, they changed the sensor, they solved it, but I have a different situation.
Faruk 2016-02-16 09:16:14
08.05.2020 19:36 # 2
Faruk
thanks to the interested friends.
we have taken care of the fault.
The sensor eye of the old case, which I brought from the owner to 85 TL, gave an incompatibility error.
I couldn't find it in the publishers, I couldn't find it anywhere.
As a result, I finally could not stand the sensorlessness, we took 250 TL and got the original.
As a result of my research, the sensor is damaged:
the new case 307's sensor eye does not come out originally these coins,
Although the old case is exactly the same, it gives an incompatibility error.
08.05.2020 19:36 # 3
sanctuary35
God should do as he knows, new cases, old case com2000 500-600lira, make up case com2000 1400lira
08.05.2020 19:36 # 4
Faruk
[QUOTE = Faruk] Thanks to the interested friends.
hello my masters
I said we bought the sensor for 250 TL, we solved the problem, but this time the system does not work in the morning, it doesn't work for half an hour or so every day, then it works all day long, the next day is not working half an hour in the morning. Due to the service he was working when he went to the machine, there was no malfunction.
as a result, I had the sensor repaired by the computer.
now it works the same on my old sensor, it starts working half an hour late LOL
the service says it is from the brain, but I don't look very warm to it,
why do you think it might be?
Is there a chassis in the barrier or is it coming from the cold or moisture?
I guess the weather will get a little warm and return to normal.
08.05.2020 19:36 # 5
I think there may be slight oxidation, check the sockets of all sensors, dust and soil may have entered. I'll clean it with contact spray. there is a chassis situation that you call me related to humidity
08.05.2020 19:36 # 6
Faruk
Thank you teacher.
I will look at the oxidisations, rather than humidity, we are comfortable in summer :)
08.05.2020 19:36 # 7
alico
I got 307 1.6 hdi in 190 thousand. What is the engine life, it is said to be maintained regularly. Is there anyone who can help?
08.05.2020 19:36 # 8
Faruk
[QUOTE = aliço] I got 307 1.6 hdi in 190 thousand. What is the engine life, it is said to be maintained regularly. Is there anyone who can help? [/ QUOTE]
good luck, you will never regret it in terms of fuel and performance, but the engine will malfunction in almost everything except the gearbox.
307 in me now 250 thousand.
Up to 70 thousand people who had maintenance in Göral,
Since 70 thousand, I have done maintenance for every 10 thousand men on the pejo.
We use 3 people inside the family, we do not give it to any foreigner.
my guess is that mine sees 350 thousand, says the masters.
The turbo can change after 20-30 thousand, because it started to whistle, but the traction is great.
If yours is well cared for and approved by the masters, it goes as much as mine.
