NOT GOING Not Eating GAS
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
17.08.2020 13:23 # 1
Efsanepartnerr
Hello friends, I will have a question for you, my 2013 model pejo partner 1.6 hdi 92lik vehicle sometimes cuts off the throttle, does not exceed 3000 rpm, does not light up any malfunction and warning lights suddenly recover spontaneously. What could be the reason? Has anyone happened to it? I will be glad if you help
17.08.2020 14:15 # 2
Professor, the general reason for this is usually the turbo electrovalve or airdebimeter.
17.08.2020 18:15 # 3
Efsanepartnerr
Got it sir, thank you. How much will it cost estimated
17.08.2020 20:16 # 4
Efsanepartnerr
Got it sir, thank you. I wonder how much cost will be estimated
18.08.2020 21:43 # 5
Bg48000
I suggest you clean your flowmeter first, it costs 20-30 TL, if you put it yourself, it will cost 50 TL if you put it in the industry, I don't know the other option.
18.08.2020 22:49 # 6
Efsanepartnerr
Thank you very much, my master, I disassembled it, I fixed it, I put it, instead the car is up and the problem is now resolved. Nicely said
19.08.2020 08:01 # 7
I am glad your problem was solved.
19.08.2020 10:54 # 8
Efsanepartnerr
Thank you very much &# 128591; &# 127999;
24.08.2020 17:17 # 9
Efsanepartnerr
Hello brother, I cleaned the flow meter. It improved for a few days but it started to do the same again. What can I do?
25.08.2020 08:10 # 10
Unfortunately, change seems necessary.
25.08.2020 08:56 # 11
Efsanepartnerr
I got it, thank you, thank you
29.08.2020 14:59 # 12
Efsanepartnerr
Ahi hello again, I'm bothering you, I'm sorry. I did not change the flow meter, but it has improved again, no problem for now. But the vehicle seems to burn too much. Does it have an effect
