Not Getting in the First Starter ..
08.05.2020 15:58 # 1
Ako06
First of all Hello .. Vehicle 2002 model 1.6 automatic 307. If the vehicle is not warmed up, the starter does not take it at the first press. but it takes the 2nd press and after working I have to gas it, otherwise it stops. Also, is it normal for the STOP lamp to flash 3 times? If the subject has been opened, I apologize. tşekkürler
08.05.2020 15:58 # 2
Muhammet CAKIR
Was there lpg in the vehicle
08.05.2020 15:58 # 3
dukenukem82
Well, my vehicle is different, but I don't turn the ignition directly. It's like yours doesn't eat more gas, you know.
08.05.2020 15:58 # 4
Ako06
The vehicle is LPG .. I do not directly turn the contact. I wait for the lamps to go out. but it is not usually the first one. STOP lamp is blinking.
08.05.2020 15:58 # 5
Ako06
I guess no one will help?
08.05.2020 15:58 # 6
This question can have many answers. It is impossible to give a clear answer. It came to my mind that there might be a fuel problem. You can change the gasoline filter first. It is already cheap. After not, you can be suported from the gas pump. In the meantime, check the battery terminals for corrosion. Clean it, if any.
08.05.2020 15:58 # 7
kaan__
the same problem is that I took the witch gasoline a little too much and used it in a few days gasoline.
