Not exceeding 3000 cycles
07.12.2020 19:29 # 1
Hoholis
Mrb friends good days 1.4 diesel vehicle while cruising in my vehicle, the diesel fuel flowed and it went into malfunction It did not exceed 3000 rpm and finally stopped, whatever the diesel fuel pouring event was settled, but the vehicle does not exceed 3000 rpm.
07.12.2020 20:21 # 2
bursae16
If the fault lamp is also on, check the socket of the egr valve. You are probably experiencing the problem due to the egr valve socket or valve failure.
07.12.2020 20:57 # 3
Hoholis
Motlor fault light is on. Could this be caused by weathering?
08.12.2020 09:18 # 4
Get well soon. First of all, have the fault codes checked in the special service that has an original software in hand, sir. In addition to what our friend said, there may be trouble with the turbo solenoid valve. the engine has protected itself. First of all, I say check the fault codes It may be another problem, not a situation related to weather. Did you delete the fault code after the process?
08.12.2020 10:11 # 5
Hoholis
No, brother, I'll go get it hooked now, let's see what will come out
