Normal temperature values
08.05.2020 16:55 # 1
FeverDog
Friends, my vehicle is 1.4hdi, the heat rises as I climb down the village road (such as a bend with a pit with a bumpy hump and a pebble, a 5-6km ramp). So yesterday, I accelerated with the fear of staying on the road and raising the gear. This also hit the car quite a bit :) When you go on this road like a human, the temperature is over 90. I wonder how long it is up to the temperature? After what time does the danger begin? :) & Nbsp;
08.05.2020 16:55 # 2
Normal up to 110 s.
Usually there is a rule that goes from mouth to mouth. Whichever gear you come down with, you should get out with that gear. I wondered which bay was this way? What is the name?
koliva 2012-07-21 11:38:30
08.05.2020 16:55 # 3
Serkan
I also have 1.4 hdi bein working at the same temperature in the vehicle, it is over 100 when going uphill and in very congested traffic.
08.05.2020 16:55 # 4
hakan38
I hope it is at 206+ lpg on the slope, 100 passes, the fan does not cool down.
08.05.2020 16:55 # 5
Cmoss06
90-100-110 normal peugeot, even love it says there is no leak until the red line .. :)
08.05.2020 16:55 # 6
tellotello
There is something I just learned. It is true that the people in the last service said it is correct, but & nbsp; "Smile" & nbsp; the first line after 90 in the temperature display, next 100 customers I thought he was jumping between 10 and 10. For this reason, he says to the master 100 but does not turn on the fan. He said let's open the fan too, and after bringing it to 95 (my 100), the top speed turned on the air conditioner and the car quickly turned on the fan while a loud fan sound came from the outside of the vehicle. Anyway, I learned something new.
& nbsp; Meanwhile, I live in an upright place in Ankara and travel around in the 90s, especially in summer they say is normal. & Nbsp;
08.05.2020 16:55 # 7
metin
If your vehicle is fully maintained, no problem. they produce the vehicles taking into account all the conditions. & nbsp;
Normally, the air that enters the water in front of the vehicle cools when cruising. If you are going slow, the fan is activated, if it is too hard, it warns you.
08.05.2020 16:55 # 8
FeverDog
Thank you for your answers, I think then it's okay.
08.05.2020 16:55 # 9
muratoner
Pejo's factory outlet fan opening degree is 105. For your information, 90 and 100 is normal heat for these vehicles.
08.05.2020 16:55 # 10
Sedat Yildirim
I was anxious about this issue, but when I serviced the car, the master said exactly what the friends said. They were working at high temperature ...
08.05.2020 16:55 # 11
elsoberano
yesterday i was in the service and after 90 they said normal up to two lines.
08.05.2020 16:55 # 12
EErgul
The low 90 is the most normal engine temperature in this weather. If the car is already under the sun, when you start the car, it turns on at 60 degrees.
08.05.2020 16:55 # 13
arachnid
Hello friends
my hot hand does not exceed 70. You are talking about 90-100, but I have never seen those values. I always use inner city. I'm not going over 15km. That's why I always say, but I went to Kumbağ last week. I did not even pass 70 degrees. Can you bring a comment. & nbsp;
08.05.2020 16:55 # 14
[QUOTE = arachnid] Hello friends
my overheat does not exceed 70. You are talking about 90-100, but I have never seen those values. I always use inner city. I'm not going over 15km. That's why I always say, but I went to Kumbağ last week. I did not even pass 70 degrees. Can you bring a comment. & nbsp;
Your thermostat is open or broken. Reviews
08.05.2020 16:55 # 15
tellotello
[QUOTE = koliva] [QUOTE = arachnid] Hello friends
There is definitely a problem with either you or us. I just arrived 15 km, some of it was downhill, it started slightly when it was descending and when I put the car in the car park it was around 85 (I should mention it in the morning, but I also know the sunless state & nbsp; "LOL").
08.05.2020 16:55 # 16
pt206
The fan starts working when it comes to around 100 normal.100. Same to me. No problem "Smile"
08.05.2020 16:55 # 17
FeverDog
Thank you to everyone. However, mine does not exceed 70 on the city within 15km. By the way, the way I mentioned is koliva in Trabzon. You can only go in 1st gear when getting off, the road is very rough; but when you need to go out alone, you go out with 2, if the car's language speaks:))) & nbsp;
08.05.2020 16:55 # 18
[QUOTE = FeverDog] Thank you everyone. However, mine does not exceed 70 on the city within 15km. By the way, the way I mentioned is koliva in Trabzon. You can only go in 1st gear when getting off, the road is very rough; but when you need to go out alone, you go out with 2, if the car's language speaks:))) & nbsp; [/ QUOTE]
The vehicle's temperature may have to do with the road, you can climb the vehicle in hot weather with the 1st gear. . However, regardless of the temperature outside, whether it is mountain or highway or down, it rises to the point where it must be (it changes according to the vehicle, whatever the 80-90 range is) and should not fall down. If there is a problem with the thermostat again, if it does not go up there, there is a problem with the thermostat again.
08.05.2020 16:55 # 19
yigiteroglu
When I first bought the car, these high values scared me very much, but as our friends say, there is no problem until 110a. It is already very difficult in 110 days. It is in the range of 90-100 in tight traffic and uneven ramp roads
08.05.2020 16:55 # 20
gibso
just like me. Let me give you a few examples; & nbsp; This winter I was in Ankara for 25 km. I was traveling 70 degrees to millimeter. Even though I returned in the same way, it was never over. They said that if there is a problem with the thermostat, it will not heat in the heater, but I hope my heater has started the car & nbsp; It was wonderfully heated for 2 minutes.
I am now in Mersin, you can predict the temperatures, there is barely 80 degrees 85 degrees or so there is no possibility of a hand, I have not seen 90 friends.
Page : / 3
