Normal headlight replacement instead of xenon
08.05.2020 17:50 # 1
salihata
Hello friends,
I have xenon headlights in my car, I will go to the inspection tomorrow. How can I replace their normal bulbs instead of removing them? vehicle pug 307 2003 xr
08.05.2020 17:50 # 2
soner09
The original sockets are still there, connect in the same way, insert the zones completely.
08.05.2020 17:50 # 3
salihata
[QUOTE = soner09] original sockets are still there, connect in the same way, insert the zones completely.
Well, is the examination also a problem xenos? headlight height adjuster but
08.05.2020 17:50 # 4
fatihgg
If you cannot go through the xenones, you can: (insert and insert the normal headlights, after pulling out, pull right again and attach it :)
08.05.2020 17:50 # 5
salihata
[QUOTE = fatihgg] If you cannot go through the xenons: (insert and put on the normal headlights, right after pulling it on, turn right to the right:) [/ QUOTE]
long work :) I'll take it to an auto electrician in the evening. If he doesn't want a lot of money, I'll have it replaced, is there a topic in the forum called xenon headlight removal? I wonder if I can
08.05.2020 17:50 # 6
Aziz
Actually it is a very simple job, but it is not apt, I guess you can get it out of the electrician, get out of the exam, give it back, let it go away from 10 TL halal, tiny things are able to turn your dreams upside down with experience ...
