noises from engine clutch and gear
08.05.2020 21:13 # 1
eroxz
Guys I have been driving my vehicle for about a month and a half. Since I bought my car, I can not get rid of the problems, although the car is now 55000 km. Due to the oxygen sensor malfunction, the malfunction lamp lit and we replaced the sensor in the special service. At that time, because of the noisy operation, the valve was adjusted, the sound was cut off for the moment, but after about 500 km, it gave the same problem again, making idle click sound at the idle and the engine is knocked over with a click sound when I press the gas. While the vehicle is in 2nd gear, it moves vibrating as if it is drowning in the 1500 to 2000 cycle band. Also, there is a click sound when pulling my foot off the clutch during gear shifts. And there is a squeak coming from the gearshift lever when shifting. There is another buzzing sound that stops when I press the clutch coming from the engine part while idling, and when I stop the car, it stops slightly jerky. What do you think could be the reasons for all this and is there a master who really understands this tool on the Anatolian side of Istanbul, thanks for your help already eroxz 2019-04-27 01:27:58
08.05.2020 21:13 # 2
x571
Get well soon. It's not something that can't be done, but you have a very long list of guys scattered officially in the car. Friends recommend the master.
08.05.2020 21:13 # 3
eroxz
Thanks. I'm waiting for your friends' help.
08.05.2020 21:13 # 4
Teacher, regardless of the vehicle's low mileage, you may encounter many of these problems in a vehicle that is used without maintenance and without revolutions. If the valve settings of the vehicle are constantly deteriorating, I recommend that you change the timing of the vehicle. I go to the European side.
