Noise from gearbox.
01.01.2023 15:53 # 1
skystar316
I have 1.4 hdi 207 out of 230 thousand. (manual) I had the transmission oil changed at 180 thousand. If it's gears for a week, there is a knock and knock, when you press the gas and load the vehicle. Not while gassing. No noise at idle either. The sound goes away when the clutch is pressed or neutral. The master said that he will lower the gearbox, he said, depending on the situation, he said that if he does not save, he will buy a gearbox. I'm a calm user, I also did the oil maintenance. Is it normal for it to do this at 230k? By the way, the oil was checked, there is oil, there is no leak. Doesn't it do this from the pressure pad? Greetings, good day guys. I would appreciate it if anyone who has experienced a similar situation can reply.
09.02.2023 21:09 # 2
Ozant.
Hello, does it happen when I give the gas in low gear and let it go, I have
It was made from the gearbox mount
