Nobody else can lift my car
08.05.2020 20:14 # 1
aalimertt
My vehicle 2004 model 307 clutches the clutch too high on departures and if I do not give gas even if it is on a flat road, the vehicle does not start with a half clutch, the cycle falls immediately, the lamps are dimmed, start shaking, the person who got into the vehicle did not lift the car the first time, I took it to the master, the pressure was over to Balat. But the master said it wasn't finished, I changed the spark plugs and cleaned the throttle, but it didn't work, now I get bored with the tremor and no gas to get up, please help, what's wrong with you?
08.05.2020 20:14 # 2
erk4n
How to create a battery?
08.05.2020 20:14 # 3
aalimertt
The battery condition is weak or rather dead, but I do not understand how it might affect the problem.
08.05.2020 20:14 # 4
aalimertt
[QUOTE = erk4n] How did the battery status be created in the battery [/ QUOTE] The battery status is weak, rather dead, but I would appreciate it if you explain how it could affect the problem
08.05.2020 20:14 # 5
erk4n
When my battery value was low, the software was deleted from there, I know why I couldn't establish the reason why it was possible to have an accident to the authorized service when the battery was renewed.
08.05.2020 20:14 # 6
erk4n
To find out if the problem is from the battery, you can reinforce it with a long cable from a solid battery and try to take off.
08.05.2020 20:14 # 7
aalimertt
[QUOTE = erk4n] To find out if the problem is from the battery, you can reinforce it with a long cable from a solid battery and try to take off [/ QUOTE] OK I will try it as soon as possible thank you
