No White Smoke from Engine
08.05.2020 21:17 # 1
myildiz42
hi friends car peugeot 307 1.4 HDI XR 2004 model yesterday I was coming from Kars with your vehicle. At 12 o'clock in the night, I parked the car in Kayseri and slept, and ran the car like 5.30 in the morning. While coming towards Adana, I saw the smoke coming from the engine at idle while standing in the opette at the exit of Kayseri. It does this only at idle, the heat cycle has dropped the oil where it works at normal idle, does anyone know what the reason is?
08.05.2020 21:17 # 2
GokhaN
hello do you throw oil from the turbo, in which region do not fat
08.05.2020 21:17 # 3
f7nepster
When the diaphragm on the rocker door is defective, oil comes into the suction from the oil vapor drain. It starts to oil on the cover and oil smoke comes out.
I changed the cover and cleaned the oil that filled the intercooler. My problem is gone.
08.05.2020 21:17 # 4
Orcun.Dmr
[QUOTE = f7nepster]
When the diaphragm on the rocker door is defective, oil comes into the suction from the oil vapor drain. It starts to oil on the cover and oil fumes are coming out. >
Hodja, I have the same problem, but when it is necessary to come to oil vapor, the oil we know comes to the turbo and the vehicle reduces the oil for this reason. I plan to transfer the oil vapor drain outlet to the crankcase with the help of a pipe. Does this diaphragm change after removing the cap? If it changes, I will give up the thought of downloading it to the sump.
