No white smoke and gas
08.05.2020 19:19 # 1
vpro
Everything was normal when friends went to internship this day. Then, while freezing, suddenly the car started not to eat gas and throw out tremendous white smoke in the middle of the road, it goes partially again, but it does not accelerate very much. Do you think it is the gasoline I bought it both in gas and gas
The weather was good rain vPro 2015-06-12 17:14:28
08.05.2020 19:19 # 2
talip206
My teacher can disassemble your air filter and see if it can get water. It also affects traction. If there is no water, you can look at other alternatives
08.05.2020 19:19 # 3
vpro
Let me see in the morning, teacher
08.05.2020 19:19 # 4
berk2309
Did you smell fuel or smell of oil? After throwing white smoke, look at the end of the exhaust.
08.05.2020 19:19 # 5
themurat54
I think the worst possibility is that white smoke is thrown in the gasket burn. I hope it is like gasoline.
08.05.2020 19:19 # 6
berk2309
In order to understand, my teacher is making the water inlet chamber, gas the lid, gas bubbling, etc. If the gasket is ticked, the gasket is ticked, when the engine is cold.
08.05.2020 19:19 # 7
madblueblacksea
If the catalyst disperses and blocks the exhaust, it gives the same symptoms. If there is no pressure in the exhaust gas, it is probably blocked madblueblackse to 2015-06-13 08:06:23
08.05.2020 19:19 # 8
vpro
The color of the water of the oil looks normal, these men who put some water as if it has passed a bit, wonder if the fuel or injectors ate water.
08.05.2020 19:19 # 9
talip206
Did you check your air filter, hodja
08.05.2020 19:19 # 10
sezar206
It's okay if the white smoke threw the rain. If the exhaust tip or something is attached, it will shatter in the medicine and the smoke will come out as you press the gas with the heat of the exhaust. I have a little more exhaust vapor than normal cars, but there is no problem in normal air. Put your air filter in, look, does it draw water? If it is not, there is a possibility of water dripping on the coil.
08.05.2020 19:19 # 11
vpro
Guys, I went 100 km this day.
08.05.2020 19:19 # 12
talip206
[QUOTE = vpro] Guys I went 100 km today, no problem the filter was a little damp [/ QUOTE]
So your filter is taking water, I think take measures to avoid problems in winter.
08.05.2020 19:19 # 13
vpro
Well, even the service took the precaution of this by drilling a hole under it.
